Previous in Forum: Catenary Curves for 72mm ADSS Fiber (Outside Aerial)   Next in Forum: Motor Lug Burnt, but Drive Didn't Trip
Why and When We Need NGR / NER?
07/24/2013 11:17 PM
hello engineers. i saw some dyn11 transformer star point go to soild grounding and some dyn11 transformer with same rating dont have soild grounding. the star point is connected to NGR/NER and then connected to grounding. why and when we have to connect NGR? i know we connect NGR to reduce earth fault current.. but i want much more clear answer.. plz help me...
Re: why and when we need NGR / NER?
07/25/2013 12:21 AM
Sounds like a Google project to me...but not for me.
Good Answers: 181
07/25/2013 1:23 AM
Think voltage and fault current.
07/25/2013 3:04 AM
For grounded system cables required are unearthed type. May be this could be your answer.
07/25/2013 3:07 AM
<...connect NGR to reduce earth fault current...>
Is that clear enough?
Re: Why and When We Need NGR / NER?
07/25/2013 10:30 AM
NGR/NER is often used to:
- Limit fault current on phase to ground faults (eg. on large generators to comply with NEMA MG-1 bracing requirements)
- Reduce circulating currents in neutrals where multiple machines are neutral grounded
- Suppress 3rd harmonic content where multiple machines or different characteristics (eg. generators of different pitch) are parallelled.
Good Answers: 244
07/25/2013 4:44 PM
This link might be helpful: http://cr4.globalspec.com/comment/589279
- MS
07/28/2013 3:49 AM
What is the capacity of your dyn11 transformer?.
Register to Reply 7 comments
msamad (1); oldtex (1); PWSlack (1); Simon Wan (1); TonyS (1); Tornado (1); vyral2311 (1)
