Previous in Forum: Gravity   Next in Forum: A Scientific Question for You Guys
24 comments
Boiled Water Audability
07/27/2013 5:49 AM
When you pour boiled water into a cup there is a different audible sound than when you pour cold water into the same cup. I have puzzled over this for some time but still not able to explain why this is so.What would a waterfall,eg Niagara sound like if the water had been boiled ? Farmer---Jack of all trades but master of none
Luck definately comes and goes----- I had a win today,,,,I saw the sun rise.
Re: Boiled water audability
07/27/2013 6:09 AM
Is the boiled water cold or is it hot?
If it is hot it is just less dense.
If it is the same temp as un-boiled water it has less gasses suspended in it so it is denser.
07/27/2013 6:39 AM
The water has just been boiled ,make a cup of tea or coffee and give it a go ,listen to before boiled and after boiled .
Good Answers: 266
07/27/2013 7:20 AM
Density of the fluid causes the change in sound. Also the increased moisture in the air as you pour conducts the sound differently.
07/27/2013 7:37 AM
It could be that the speed of sound waves in the cup is changing as the cup gets hotter. A cold cup will likely sound different than a warm cup - the pitch should drop as the cup gets warmer. Is this is what you hear?
Or maybe I should say it's not (necessarily) the 'speed' per se, but the stiffness of the cup that changes as it gets warmer, which affects the pitch.
07/27/2013 8:04 AM
If it is speed of the sound waves that is altering the sound , if you pour boiling water into a glass the glass will break,if you put a spoon into the glass before you add the boiling water the glass will not break, is it the sound waves that break the glass or the heat ?
07/28/2013 8:44 AM
The velocity of sound in the hot water is different, making the resonant frequencies different for hot water than cold water. It's the same effect as breathing helium changing the resonant frequencies of your voice.
07/27/2013 9:00 AM
07/27/2013 10:54 AM
Top answer ,boiling water must have different properties because if you put cold water on a teabag very little happens but when you put boiling water on a teabag the infusion is very evident. Is the reaction thermal or harmonic ?
07/27/2013 10:59 AM
Boiling water would have a different viscosity and surface tension than cold water, which would help to explain the faster absorption rate of hot water.
Not sure if harmonics plays into this at all, but molecular action would be greater in the hot sample.
Good Answers: 27
07/28/2013 9:28 AM
I believe that when adding heated water into a tea bag, you just have added heat that served as a catalyst thereby speeding up /and triggering the chemical processes. Have a nice tea!
vsar
Good Answers: 11
07/27/2013 9:56 AM
Sounds travel faster in solids. Most material tend to solidify when frozen . That's why audibility is dependent to temperature- cooler most audible than hotter ones in general.
In Vacuum there is no sound at all.
07/27/2013 10:00 AM
What you say makes no sense at all, in relation to hot water.
Does sound travel faster in hot water??
Good Answers: 11
07/27/2013 9:50 PM
Sound is characterized by molecular vibration(wave form), mechanical in nature.
Below is the explanation of wikepedia, best to explain relationships to sound
http://en.wikipedia.org/wiki/Speed_of_sound
Nope, sounds travels faster in cold water rather than hot water, the same effect to surroounding air.
07/27/2013 9:59 PM
Correct.
07/27/2013 11:05 AM
With no sound in vacuum,is sound more audible in a compressed situation. Would sound be more pronounced at higher altitudes compared to sea level ?
07/27/2013 11:33 AM
Sound is a function of density. More dense, faster sound propagation.
Higher altitude less dense.
Speed of sound - Wikipedia, the free encyclopedia
07/27/2013 12:29 PM
Should we be listening and watching movies in a compressed air environment to increase
the entertainment value ?
07/27/2013 12:40 PM
No. Use head phones.
07/27/2013 1:05 PM
Commonsense prevails.
Re: Boiled Water Audability
07/27/2013 10:42 PM
Boiled water has no dissolved gases. It can have a different compressibility from water saturated with air.
bioramani
07/28/2013 7:36 AM
You are also changing the "resonance" of the cup...it's size will change with cold or hot. One will contract the cup, the other will expand it making the resonance different.
07/29/2013 9:40 AM
The heat, the BTU transfer to the glass makes the glass expand too fast. The spoon not only cools the water off just a little it also disperses the water so the heat is more evenly distributed. Ceramic has a much lower heat explanation factor than glass and borosilicate is somewhere in-between.
07/29/2013 10:15 AM
One last thing, the actual breaking is due to one small part to the glass expands rapidly while the rest does not. By slightly cooling and spreading the flow more of the glass expands and a bit more slowly. I bet you could prevent the glass from breaking if you allowed only a table spoon of hot water hit the bottom of the glass then wait for a second before you poured normally.
Good Answers: 44
08/05/2013 2:40 PM
Pouring boiling water or cold water into your ear also sounds quite different.
Register to Reply 24 comments
129CBRider (1); aDIYguy (2); bioramani (1); cuba_pete (1); lyn (6); Maurie (6); Noudge79 (2); ozzb (1); Rixter (1); Tom_Consulting (1); Usbport (1); vsar (1)
