Previous in Forum: Earth Fault Relay - MLN98V300   Next in Forum: Ferro-Resonance?
Motor Protection Settings:- Thermal Time Constants in REM 615
08/02/2013 12:49 AM
I am working out motor protection settings for 700kW motor, relay is ABB make REM 615, in thermal overload protection we have to set three different time constants viz. Time constant start, Time constant normal and Time constant stop. I need guidelines on how to set them.
In motor manufacturer datasheet cetain time constants are given which are as:
Thermal copper time constant - 9 min
Thermal time constant (long term)- 25 min
Thermal time constant for cooling down (standstill)- 175 min.
Kindly help.
Re: Moto protection settings:- Thermal time constants in REM 615
08/02/2013 1:11 AM
Basically, the first three you gave match in respective order the second three.
08/02/2013 2:04 AM
but setting the Thermal time constant start= 9min (540 s) will result in tripping since the starting current = 6 x In and starting time is 31 Sec, according to trip curve given in technical reference manual of REM 615
08/02/2013 3:16 AM
How did the phone call to the motor manufacturer go?
Good Answers: 19
Re: Motor Protection Settings:- Thermal Time Constants in REM 615
08/03/2013 1:35 AM
Try the above settings.
Ramesh,Freelance Electrical/automation Consultant
Good Answers: 42
08/05/2013 4:52 AM
In my opinion 9 min it is rotor locked [short-circuit]thermal constant, 25 min it is for overload estimation temperature and 175 it is for cooling -in standstill position-if two or more startings are involved.
If motor parts are heating the temperature rise is : DT=Tconductor-Tambiant=Tinf*(1-exp(-t/Tk).
For instance, if stall time[from the motor catalogue] is t=10sec and maximum DT=130-40 [for class F insulation and 40 dgr.C ambient] then Tinf1=90/(1-exp(-10/60/9))=4905 dgr.C[if the motor will stay in locked rotor position infinite time!]Then for 5 sec start time DT=4905*(1-exp(-5/60/9))=45.2 dgr.C.
If we want to know what could be the temperature when the motor is stopped and not energized after t3 sec. DT=Tload*(exp(-t3/Tk3) If Tload=Trated=90 and t3=1 min then DT=90*exp(-10/175)=85.
In usually load condition[rated]Tinf2 has to be 90[130-40] then for an overload of x% Tinf2x%=Tinf2*(1+x%/100)^2 and DTx%= Tinf2x%*(1-exp(t2/Tk2)). For instance x%=30,t2=1 min.
DT30%=90+90*(1.3)^2*1-exp(-1/25))=96 dgr.C
See also:
https://www.selinc.com/WorkArea/DownloadAsset.aspx?id=3690
Julius
7anoter4 (1); PWSlack (1); ramvinod (1); Tornado (1); vyral2311 (1)
