Previous in Forum: Welding Procedure Deviation from PQR   Next in Forum: Duration of Hours a Submercible Pump Can Run Without Stop
9 comments
Electrode Qualification Test
08/11/2013 1:26 PM
Dear all Member,
I have a query regarding electrode E6010 (3.2mm) & E8010-G (4.0) (SMAW) electrode qualification test.
which size and how many plate required for test, also how many equipment use in EQT ?
because , i will do frist time EQT.
Thanks & Regards,
VK
Pathfinder Tags: mechanical engineering
Re: Regarding electrode qualification Test
08/11/2013 1:33 PM
To which qualification do you refer?
You need the specification, not just someone to give you free advice.
This information MUST SURLY be in the specification, otherwise, why would you care what it was?
Asking strangers is a risky business.
08/12/2013 10:13 AM
SURLY ≠ SURELY ≠ SHIRLEY
08/12/2013 12:42 PM
No, Lyn surely is surly. (Only with those not posting sufficient information to even make a half-hearted attempt to provide them with an answer that might solve their dilemma. Or those looking for answers to their mid-term take-home exam.)
08/12/2013 12:52 PM
I always get the spelling wrong. I think there surely should be an "H" in there somewhere.
Surely/should
Home/comb/womb
read/read
Where's Gallagher when I need him? He's got an extra "H" in his name I could use.
10/29/2013 6:59 AM
"I'll be frank with you."
"Oh no you won't! You were Frank last night."
"Surely you jest!"
"Stop calling me Shirley!"
"I'm not kidding" said the Ewe to the Ram.
English can be confusing as a second language.
04/23/2024 9:23 AM
Re: Electrode Qualification Test
08/12/2013 8:54 AM
Here is a link to begin your quest:
http://www.pbs.org/wgbh/amex/pipeline/sfeature/welding_manual.html
Good luck.
10/29/2013 4:35 AM
Mr VIK517
THE ELECTRODE QUALIFICATIONS MAY BE THE PHY.TEST OF WELD DEPOSITION IN THE WELD JOINT AND IT IS CALLED AS ALL WELD TEST. THE TENSILE SPECIMAN IS TAKEN OUT FROM THE WELD DEPOSITE AND TENSILE TEST IS CARRIED OUT.THE RESULTS OF UTS SHOULD BE CLOSE TO THE PARENT MATRIAL PHY. PROPERTIES.
04/23/2024 7:51 AM
Please stop SHOUTING! Some people here are trying to get some sleep.
Register to Reply 9 comments
Brave Sir Robin (1); HiTekRedNek (3); lyn (2); PWSlack (1); rajan_bhiwandkar (1); Tornado (1)
