Previous in Forum: Pneumatic Control   Next in Forum: I Thought I Knew Thermocouples...But
Delta PLC High Speed Counter
08/29/2013 4:50 AM
hi
i am using dvp24es2.
i am using C251 and C253 hi-speed counter for 2-phase 2 inputs sucessfully but when i add C233 and C234 hi speed counter for more input count, compiler gives an error.
i dont know why?
i need to write a program to read 4 high speed counters.
thank you
Pathfinder Tags: PLC
Re: Delta PLc High speed counter
08/29/2013 6:53 AM
Consider the possibility of the counter function requiring two contiguous bytes of memory. What happens when C234 is changed to C235, for example <rhetorical question - NNTR>?
Re: Delta PLC High speed counter
08/29/2013 11:22 AM
Good eye! I saw the 251-3 skip, but the possible implication didn't register. I hope the OP does reply, so that we can know if this turns out to be the issue.
Re: Delta PLC High Speed Counter
08/30/2013 7:40 AM
There are 2 type of High Speed counters: Software & Hardware types.
C251 & C253 are hardware HSC, using X0,X1 & X2,X3 respectively.
C233 & C234 are software SHSC using X4,X5 & X6,X7 respectively.
You cannot use the same input for 2 different counters. This will give syntax error when executing DCNT instructions.
Check that you did not double designate in the firdt place.
You should download the Operational manual-programming for the DVP-ES2_EX2...pdf. This will show you how to check the errors as well on the limitations for using the counters etc.
04/30/2015 5:37 AM
Suggest an industrial automation website to us, may be can help you, there are many delta plc online sale, the most importance is customers can get a technology support 24/7, even weekend,
FastToBuy.com
Register to Reply 4 comments
DavidJohnLee (1); LAA_Lucke (1); PWSlack (1); Tornado (1)
