Previous in Forum: Float Type Level Gauge for Cryo Application   Next in Forum: Coefficient of Friction
19 comments
Sprocket's Pitch
09/02/2013 5:48 AM
is it possible to find pitch of sprocket with no. of teeth in hand??????????
how???????
loves learning........ do u love to teach?????
Re: sprocket's pitch
09/02/2013 5:50 AM
Yes, though it would be easier to measure the distance between the centres of the pins in the chain that passes over it.
09/02/2013 5:56 AM
What's with the excessive punctuation? It is highly unprofessional.
The number of teeth does not tell the pitch; the center-to-center distance does, and can be measured. In the U.S., the first digits of the sprocket number usually tell the pitch directly, with some "code" involved.
09/02/2013 6:01 AM
formulas??????????
09/02/2013 6:06 AM
p = 2 r sin (pi/n).
Once again, what's with the unprofessional punctuation?
09/02/2013 6:11 AM
p refers to pitch
r refer ?
n refers rpm
09/02/2013 6:20 AM
r = radius
n = number of teeth
Rpm is completely irrelevant at this stage.
09/02/2013 6:30 AM
only value I know is no. of teeth.
09/03/2013 10:05 AM
Too bad. That's not enough to determine an answer. What - is there no measuring tool available there?
09/02/2013 6:07 AM
Imagination?????????????????????????????????????????????????????
Anonymous Poster #2
09/02/2013 6:10 AM
If you have the sprocket in hand, roll it very hard. Then measure the space between skin punctures.
09/02/2013 6:17 AM
...then multiply the distance between puncture marks by the difference in radii of the tooth tip radius and the chain centres radius.
09/02/2013 6:27 AM
09/02/2013 6:30 AM
The pitch cannot be deduced from that alone.
09/02/2013 6:33 AM
ok.
09/02/2013 6:49 AM
what specification required?
09/02/2013 6:58 AM
Size.
Good grief; see the formula already given. Notice the r in it.
09/02/2013 3:49 PM
平靜地走開
The above can be translated to :GO AWAY QUIETLY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
TAKE YOUR SPROCKET WITH YOU.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
09/03/2013 10:04 AM
...preferably to the local bicycle repair shop. There has got to be someone there who can help.
09/02/2013 7:07 AM
Take the sprocket to the local bicycle repair mechanic's premises, and ask there.
Register to Reply 19 comments
Anonymous Poster (7); lyn (1); PWSlack (6); Tornado (5)
