Previous in Forum: Electrical Schematic   Next in Forum: Flash Over Due to Short Circuit in Busbar Connection Side of MCCB
20 comments
CB Operation Time Versus Velocity
09/02/2013 7:10 AM
Hellow everyone!
I ask to help in understanding the concepts: what are the difference between a "close\open operation time" and "close/open velocity" of power circuit braker"? Is it possible that a close\open time is fine, but the close\open speed is wrong?
Thank you for co-operation :-)
Leon
Re: CB operation time versus CB operation velocity
09/02/2013 8:27 AM
What sort of breaker? Please give the forum something to go on. Maker? Part number? How about voltage and current?
The more information that can be provided during the initial posting, the more concise and quicker will come the answers.
09/02/2013 8:28 AM
Of course, by the factor of distance. (Which makes the distinction between velocity and time.)
09/02/2013 8:41 AM
OK. Let see: rated closing time (from technical documentation) =50 mS. Measured closing time (field measurement by CB analyser) 49 mS. What can i learn more about CB health by velocity measuring ?
09/02/2013 8:51 AM
Simply that the closing time is 2% faster than specification.
09/02/2013 9:00 AM
Measure or compute the velocity, and see if it also conforms to specification.
For instance, time relates to total let-through energy; velocity relates to arc quenching and possible contact bounce.
If kvsridhar is observing, he can surely amplify on these brief comments.
India - Member - New Member
Good Answers: 164
09/03/2013 12:10 AM
Thanks for the vote of confidence Tornado
Closing velocity, if high at the point of contact-touch, causes bounce. Today's contactors have electronically controlled coils, which regulate closing force so that bounce is practically eliminated. As opposed to old contactors which used to slam shut bouncily.
Fast opening is mostly desirable, to quench the arc quickly. Won't help in zero-current devices like contactors, but current-limiting devices (eg. MCCBs) are helped by a high opening velocity.
My two cents, for what it is worth.
Good Answers: 181
09/03/2013 12:46 AM
It's a long time since I've had trouble with contact bounce.
Thanks kvsridhar for reminding me of some long weary shifts on old switchgear.
Regarding the opening velocity, there's something nagging in the back of my mind about the zero current point being used to stop the arc being drawn out before the end of contact travel.
Old age is getting to me
Good Answers: 164
09/03/2013 1:18 AM
Old age? Going by many of your posts, i beg to differ. What worries me is, who will be there to give the benefit of experience to the next generation...but then. where are those from whom we learnt much of what we know...so, the next gen will take care of themselves i suppose.
Yes, considerable work by designers has pactically eliminated problems of contact bounce, so it is not so alarming now.
Yes, you are right in thinking that very fast opening is not always good. Especially in contactors, where a slow opening allowing a current-zero quenching may occur. But by and large, quick opening helps.
i must remind the OP that 'velocity' is not quite right, 'speed' is better for most devices, and 'angular velocity' is appropriate for single-break devices eg., CBs. And any speed is an average value only, since the moving system is accelerating always. So closing speed at contact-touch is important, while opening speed at contact parting is important.
09/03/2013 2:04 PM
Velocity is the in distance travelled in a unit of time.
Close/Open time is the time it took to execute the open action completely.
The difference: if the distance = 10mm, and it took 50ms, then the velocity is 200 mm/sec. This is needed in relation to the arcing potential during opening, i.e. how efficient it is in preventing any arcing.
09/02/2013 9:02 AM
open / close operation time v/s open / close velocity
its difficult to say
velocity = d [distance ] / time
in automatic breaker u can find a open / close time using simulator
in instantaneous tripping mode at the time of breaker opening time ranges in.mili second s
as you know distance between breaker contacts open position and close position
you can find a breaker open / close velocity !! using breaker open / close time
open / close velocity mainly depends upon spring used in breaker [k]
as breaker spring become old you got low velocity in open / close operation of breaker
not much that you can assume
09/02/2013 9:03 AM
09/02/2013 10:01 AM
Thank you all for your answers. My question was caused by the fact that my company has purchased CB analyzer without displacement kit. I'm trying to find arguments for what would convince their managers of the need to purchase motion transducers. Unfortunately so far I do not find among your answers, colleagues, quite convincing arguments! "Measure the speed and compare with CB technical data" unfortunately does not work when it comes to money :-( "The operating time in the normal range? What more do you want? Do you work in the Electric Company, not in university laboratories" - The answer I get.
09/02/2013 10:05 AM
Next time, put all that in the original post.
09/02/2013 10:19 AM
PWSlack! I'm really trying to find arguments. What's wrong with how I built my question? There are some rules on construction issues in the forum?
09/02/2013 10:23 AM
Maybe the money guys know how to do arithmetic better than you do.
Good Answers: 164
09/03/2013 11:45 AM
Er...i did mention that the time/distance calculation gives AVERAGE speed. What is important is the instantaneous speed at the point of contact-touch and contact-parting. The transducers can tell you that. Best argument for convincing higher-ups. Depends on your passion in needing to find out this speed.
Re: CB Operation Time Versus Velocity
09/02/2013 3:32 PM
"I'm really trying to find arguments"
Many here don't care to waste time arguing with unqualified people on subjects about which they demonstrate ignorance.
Good Answers: 122
09/03/2013 10:55 AM
"close/open operation time" is the period of time that it takes for a CB to transition from one state to another. "open position-to-close position" and "close position -to open position".
"close/open velocity" is the speed at which the CB contacts are moving.
"close/open operation time" is directly affected and is a result of CB "close/open velocity" and contact gap.
Yes it is possible that "close/open time" is fine but the "close/open velocity/speed" is wrong.
Given Conditions:
1. The contact gap is set at less than CB design value.
2. A mechanical malfunction condition exists that decreases the "close/open speed" value.
Resultant:
Because the pole piece has less distance to travel the "close/open time" could still within acceptable limits even though the "close/open velocity/speed" is defficient.
Good Answers: 22
09/03/2013 5:22 PM
The condition of a faster speed can also occur with the incorrect springs installed in an air circuit breaker. I went out for a factory recall for this condition on AM type indoor 15 KV units. The tighter springs moved the contacts too fast and the arc never made it to the proper position in the arc chute. Most had never interupted a fault and were a simple fix, but a few were quite damaged. The QA foreman had decided that even though the speed and opening time were under spec, it would not cause a problem. It turned out to be a very big problem.
Vacuum bottles are much easier and more dependable.
09/05/2013 4:05 AM
Many thanks to all who responded to my question! The discussion reinforced my belief that the checks at the time of commissioning and periodic inspections must include not only the response time measurement, but also the definition of the speed of the main contacts.
Register to Reply 20 comments
4wsilver (1); kvsridhar (3); LAA_Lucke (1); lyn (1); MUSUTH86 (2); PWSlack (3); relay59 (4); SHOCKHISCAN (1); TonyS (1); Tornado (3)
