Previous in Forum: Current in Superconductors   Next in Forum: How Does an Electric Generator Match the Grid Frequency?
33 comments
Electric Shock
09/03/2013 12:48 AM
Another electrical question...
Why don't I get an electric shock if I touch an electric element (oven, grill, toaster etc)?
Re: Electric shock
09/03/2013 1:13 AM
Because you may not have yet made a circuit through part of your body. Basically, two parts of your body must touch two different points with voltage between them.
Re: Electric shock
09/03/2013 1:51 AM
But say a stove element (one of those curly ones)... if I stick one hand on that and the other onto an earth pole - surely I'm not going to get a shock? (A burn, maybe, but not a shock).
Re: Electric shock
09/03/2013 2:07 AM
It depends. The heating element usually has the conductor surrounded by ceramic and then by the outer metallic sheath, and thus is not normally live. However, damage can occur so that electrical contact is made. In that case, a shock is possible.
Re: Electric shock
09/03/2013 2:11 AM
Thanks - I didn't realise they were constructed that way - now it makes sense.
Good Answers: 109
Re: Electric shock
09/03/2013 7:45 AM
Whatever you do, dont try it out! Dont touch an oven element when heated either.
Just saying!
Re: Electric shock
09/03/2013 11:08 AM
Too late - I'm now in the burns unit.
Good Answers: 109
Re: Electric shock
09/03/2013 11:59 PM
Bugger! You need to ask more questions before you touch anything . . .
Good Answers: 804
Re: Electric shock
09/03/2013 10:20 AM
What he said there is very important. There can be micro cracks in the ceramic that do not affect current flow when a pot or pan is on the element, because the pot or pan is resting above the conductor (NiCh wire) on top of the rest of the intact ceramic coating. But your finger, because it is more flexible and relatively wet, can make contact.
And by the way, most toasters do NOT have ceramic coated heating elements, so you CAN be shocked by touching them. They heat up so much faster that your own protective reflexes would pull you back first. That's why you must NEVER use a metal utensils to remove toast if the toaster is plugged in, the utensils delays the heat transfer, but not the electricity transfer.
Re: Electric shock
09/03/2013 10:32 AM
...which is why a toaster, such as the one in #7↑, is normally fitted with a double pole switch that opens both contacts while ejecting the toast at the end of the toasting time. If some silly nerk puts a fork in there to get it out, there is little risk of an electric shock with both live and neutral disconnected, even if they are the wrong way round in the plug.
However, there is nothing stopping shock if the fork is inserted while the thing is still toasting, which is why kitchen circuits installed to the latest edition of British Standard 7671 are fitted with 30mA residual current devices to disconnect the supply and prevent that prime walrus getting a fatal electric shock. At least, that's the theory, anyway.
Re: Electric shock
09/04/2013 5:23 AM
Re PWSlack comments in post 8 about 30mA RCD's. These are common now and mandatory, but 50 years ago they were a novelty. I was involved with a company that sold them (pioneered them actually), and to demonstrate how effective they were I thought I would touch the live wire to show that they tripped out.
What seemed a good idea at the time turned out to be rather daft.
Yes the RCD tripped and I am still here to tell the tale, but I got an almighty poke in the few milliseconds it took to trip. And I bashed my elbow in the recoil. And worse from a sales point of view, the customer who was interested in RCD's to prevent electric shock, was left with the clear and obvious impression that they did nothing of the sort.
Hence the importance of qualifying the claim by adding 'fatal'. As PWSlack has done.
Re: Electric shock
09/03/2013 10:15 AM
A modern installation to the latest edition of British Standard 7671 would have a 30mA residual current breaker on a cooker circuit so that, were the fault situation in #3↑ arise, then human contact with a live part would cause it to disconnect the circuit before the individual received a fatal electric shock. At least, that is the theory.
Re: Electric Shock
09/03/2013 2:10 PM
turn it up higher next time
Re: Electric Shock
09/03/2013 10:19 PM
Don't try it with bare feet!
Floss or die!
Re: Electric Shock
09/03/2013 10:24 PM
actually my original question was a bit misleading - I have never touched a toaster element... with anything...
But it's pretty easy to touch the electric stove elements - good to know the layer of ceramic is there!
qq
Good Answers: 42
Re: Electric Shock
09/03/2013 10:25 PM
Most stove elements with the outer metal layer actually earth ground that outer layer. If not directly, then through the metal frame of the stove.
Good Answers: 12
Re: Electric Shock
09/03/2013 10:28 PM
Don't try this either
Electric Guitar
Good Answers: 203
Re: Electric Shock
09/03/2013 11:17 PM
Besides the appliances/uses mentioned a defective electric hot water heater can result in the same shock. Most electric water heaters are 240v with no neutral. If the covering over the heating element(s) has cracked or is broken it will conduct through the water, especially if there are some minerals in the water and the heater is ungrounded.
When you touch a grounded device, (shower head, faucet, etc) while having your hand in the water there will be a flow of electricity from the shower head through you to the water. Electricity takes the path of least resistance and you wet are it. The side of the element crack with the lowest resistance (shorted end) will allow electricity to flow from the element, through the piping, through the water and through you. Isolate yourself by breaking that path, stop touching the shower head, and the path is broken.
If you find this happening change the elements immediately. From my experience with this, the rustier the interior of the tank is the worse it is. This is especially true if the rust flakes are high enough to touch or cover the broken element.
A good way to test for this is to take the temp of the water. If much higher than the set temp you have a problem. An even faster and better way is to use a clamp-on amp meter on the element wires. If there is an unbalance then there is problems. Also try it when the thermostats should have stopped heating. Any current at that time is also a problem, most thermostats are single pole so one side is always hot electrically.
Good Luck, Old Salt
Re: Electric Shock
09/04/2013 2:39 AM
Thanks - interesting post!
Good Answers: 203
Re: Electric Shock
09/05/2013 10:51 PM
Although some individuals have a difficult time understanding or believing it, under certain condition you can get a shock from a 12 volt car type battery.
Get your body nice and sweaty, dip your hands in sea water and touch both terminals of the battery with fingers of the same hand. You should feel a slight shock across the hand. DO NOT ATTEMPT THIS WITH BOTH HANDS, ONE ON EACH TERMINAL! Done that way, across the heart, could cause a potentially fatal heart attack or defibrillation of the heart.
Case in point- I have a 20' wooden sailboat. It has a stainless steel center board (metal plate that sticks out the bottom of the boat into the water) that is about 4' long. This centerboard in grounded to metal parts of the mast for lightning protection. I sail in salt water.
The negative terminal of the battery for lighting is also grounded as is required. I was sitting in the cabin with my feet in a small amount of bilge water after sweating a lot. I touched a positive wire in the electrical panel and felt a small shock across my hands, arms and leg. What had happened was the good conductor of the sweat on my body, my feet in the salt water of the bilge, my one hand gripping the metal centerboard and touching the positive wire created a path of low resistance which caused the voltage to flow through me. Much to my surprise I felt the low voltage, 12 volts, shock and could reproduce it. My feet in the salt water, the metal centerboard in the salt water, the negative terminal being grounded, sweaty body, sweaty and salty hands and touching the positive wire all combined to have electricity shock me enough that I could feel it. Again, this was only 12 volts!
For anyone with an implanted defibrillator, don't even think about doing this! It could cause your defibrillator to activate and shock your heart. If that occurs it is much more painful than this 12 volts was.
Good Luck, Old Salt
Good Answers: 42
Re: Electric Shock
09/06/2013 11:45 PM
"I felt the low voltage, 12 volts, shock and could reproduce it"
MASOCHIST!
Hobbies - CNC - New Member
Re: Electric Shock
09/04/2013 8:29 AM
There is a difference between an oven element and a toaster element.
  1. Never touch either when they are on.
  2. Never use a metal instrument to get anything out of said toaster.
  3. The oven element is surrounded by ceramic and covered in a metal jacket, so you wont get shocked.
  4. However, with a toaster it is usually a NiChrome wire element, meaning that you put the hot to one end and the neutral to the other and you get a giant resistor that glows and toasts your bread and there is no outer sheath.
  5. Here is a diagram:
Good luck and keep your hands out of where they don't belong!
BA
Re: Electric Shock
09/05/2013 4:42 PM
I had questions like this as a child, at about 4 I unscrewed a light bulb from a lamp, stuck my finger in the socket and turned the switch...it felt 'tingeley'. I think I was only touching the center post, no good ground. Kind of like Ben Franklin's kite flying during a thunder storm. Experiment...then reason it out! Or maybe reason it out, then experiment.
Re: Electric Shock
09/05/2013 9:54 PM
If the stove's heating element wasn't encased in ceramic then placing a metal pot or frying pan on it would short out the element, think about it.
Re: Electric Shock
09/09/2013 1:55 AM
New toaster elements read in the GigaOhms when you measure from one lead to the other with a megger. Therefore you will get such a small amperage when you touch it because most of the amps are converted to heat.
Re: Electric Shock
09/09/2013 2:25 AM
Back to school, Gary.
Floss or die!
Good Answers: 203
Re: Electric Shock
09/09/2013 8:38 AM
Help me, has Ohms Law been found to be unconstitutional by the supreme court of electricity?
My wife's toaster is a 1,000 watt unit. Since it is a 120 volt unit Ohm's law would have said that the current was 8.3 amps, (P = I * E, therefore I = P/E) since 1,000 watts/120 volts = 8.3 amps. Now if I solve for R, resistance, the calculation should be R=I/E according to Ohm's Law. That would mean, E being 120v and I being 8.3 amps) the resistance, R, should be 120v/8.3amps or 14.4 ohms.
If a megger measurement was one GigaOhms, 1,000,000,000 ohms, then I=E/R would be I = 120/1,000,000,000 or 0.00000012 amps which equals 0.12 microamps.
Most things of this nature tend to increase their resistance when heated. For a similar example, the resistance of a light bulk is at it's lowest when unlit and highest when lit. Granted a heating element that is insulated will heat up with electricity applied to it but touching it will produce a burn due to heat and not electricity since it is electrically insulated. Take an non-insulated heating element, touch it with electricity applied to it and you would get a burn due to thermal and electrical contact.
Perhaps the calibration of the meggar needs to be checked. Or perhaps we all need to recognize the updating of Ohms Law.
Good Luck, Old Salt
Re: Electric Shock
09/09/2013 1:55 PM
A megger will measure the resistance of the insulation not the resistance of the circuit (unless you deliberately do so).
And yes, I did do it with a calibrated megger (required calibration once a year to ensure consistent readings) because that's what is required in the naval shipyard. The lowest acceptable reading from a megger on naval lighting circuit is 500,000 Ohms.
http://www.navsea.navy.mil/CNRMC/SERMC/SSRAC1/nsi/13nsi/009-22_FY13.pdf
Good Answers: 203
Re: Electric Shock
09/09/2013 4:26 PM
garyrich2000-
My answer was based on the statement: New toaster elements read in the GigaOhms when you measure from one lead to the other with a megger.
As many know, including you and I, a megger is a unit that is connected to wires that form an open circuit in order to measure the conductance between the wires. When indicated in ohms this is normally every high.
Based on the above quote the megger was connected to each lead of the toaster element. A toaster element is a conductor having a low resistance from lead to lead therefore the megger would indicate a very low resistance, not a high resistance when the megger is used in the normal manner. If the toaster element was connected to an open SPST or DPST switch in series with the element the megger would indicate a high resistance if there was no defect in any of the components.
My viewpoint is that this original was probably composed in a little rush, as most of use will admit we do, and it was simply an incorrect keyboarding incident. I understand what you are stating but others may not be as fortunate.
Good Luck, Old Salt
Good Answers: 42
Re: Electric Shock
09/10/2013 11:14 AM
Push the toaster lever down. There is a contact that breaks the circuit. Some need power to pull in the relay that connects the elements.
Re: Electric Shock
09/09/2013 7:07 PM
Thank you for the response Mr Salt. and others on this site whether it's positive or negative. If I make an incorrect statement I welcome the corrections to fine tune my responses. Without such feedback I'd be at risk to repeat the same remark. So again, thank you much.
The megger reading I pictured is across the ceramic insulation in 3 phase reading each phase to ground and each phase to each phase while disconnected from the wiring. While in single phase, this high ohm reading would be from one terminal to ground but not terminal to terminal as I mistakenly stated.
Good Answers: 203
Re: Electric Shock
09/09/2013 7:59 PM
garyrich2000-
No problem, we're all (at least most of us) in the same boat figuratively speaking. We try to do the best we can with what we have during the available time that we have. Just like you have demonstrated, we all make a minor mistake sometimes and we need the assistance of one of our colleagues to give a minor boost of help to us. It is human to make a small mistake but it is much better to help someone who wants help.
Your message is very admirable and reflects the type of person who does not give answers to exercise their damnation skills, to make fun of someone else, or to see how much someone can be ridiculed. Personally, I hate it when someone acts the ways I have indicated. What I do is literally bite my tongue and go on. Each must realize that a large majority of the users of this forum are here to help people who might not be as fortunate as you to have the skills and talents you do. Although some people may really pi_s you off sometimes, we have to remember that there is only a few whose presence here is not for the betterment of others.
As you continue on here I feel confident you will see that there are some really fine people who you would still like if you met them in person. How more basic way can you learn about someone than with only their words. No other distracting traits. I feel this is true because I have met some really fine individuals here. Many I wish I could meet face to face. Everyone I have asked for help, and many I didn't ask but recognized I needed it, has always wanted to be as helpful to me as they could and them give some more beyond that.
What ever anyone posts, just remember some of us have great minds in numerous disciplines, some have great minds in a few disciplines and average in others, some have average in many or average in one or two disciplines, some have no skills but want to learn more. Just remember though, the ones with the minds with great common sense engineering are the ones who can communicate with others and get the task completed. Hope I haven't been too philosophical.
Good Luck, Old Salt
Re: Electric Shock
09/10/2013 11:24 AM
Yes, but you also said "Therefore you will get such a small amperage when you touch it because most of the amps are converted to heat." which is totally false. Depending where you touch it, (live side?) and what you are connected to elsewhere (bare feet on conductive floor, e.g.), you may have low resistance and mains power - with Niagara Falls behind it. Kentucky Fried, anyone?
Floss or die!
Good Answers: 42
Re: Electric Shock
09/12/2013 10:45 AM
Thailand, Niagara falls, Kentucky Fried-- thats world travel!
Register to Reply 33 comments
Captain Quirk (1); daffy (1); Fredski (1); garyrich2000 (3); geraldpaxton (1); GW (4); horace40 (1); IdeaSmith (2); JRaef (1); old salt (5); Original_Macgyver (1); PWSlack (2); questionsquestions (5); Stuart21 (3); Tornado (2)
