Previous in Forum: Level of Accuracy for Pressure Gauges   Next in Forum: WPS/PQR/WPQ
RTJ Gasket
09/03/2013 6:43 AM
Dear ALL,
There are some question that need your support :
1. Is that allowable by asme to use R54 RTJ gasket to replace R53 RTJ Gasket?
2. What the impact when we do that replacment?
thanks for your support
Regards,
Iqbal
Pathfinder Tags: Asme B16.20 RTJ Gasket
Re: RTJ Gasket
09/03/2013 6:51 AM
In the spec, does it say words to the effect that either R54 RTJ gaskets or R53 RTJ gaskets may be used? Only, it's a bit difficult to see the document from here.
Re: RTJ Gasket
09/03/2013 7:02 AM
Did you buy the wrong ones?
Re: RTJ Gasket
09/03/2013 9:54 AM
Flange pressure rating for R53 is 900# and R54 is 1,500#.
You decide.
Re: RTJ Gasket
09/03/2013 10:32 PM
You might not be able to squeeze the R54 gasket enough to seal tightly.
Good Answers: 109
Re: RTJ Gasket
09/03/2013 11:57 PM
1. No
2. deadly serious if you are unlucky
Anonymous Poster (1); IdeaSmith (1); lyn (1); PWSlack (1); Tornado (1)
