Previous in Forum: Fiscal Metering   Next in Forum: Design Pressure - Full of Water and Static Head
Non Contact Radar Level Calculation
09/07/2013 3:43 AM
I am suppose to make a speedsheet that can be use for level calculations of non contact radar instrument. Given the formula D= C.t/2. whereD is the empty distance from the top of the Tank to the liquid.( with know tank dimension, the level of liquid can be calculated)C is the speed of light. (3 x 108 m/s) Maxwell`s theories of electromagnetism confirmed by Heinrich Hertz experiment shows that all electomagnetic radiation travels at the speed of light.Since I want a general calculation that would be applicable to difference frequency variations, do I use C(speed of light) directly? how would the difference in frequency be considered?How do i calculate the time of flight t.????
Re: Non contact Radar level calculation
09/07/2013 6:23 AM
DO your own homework.
09/07/2013 6:57 AM
Search the 'net to find an equation expressing the dependence of the speed of light on frequency. Let us know when you find it.
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: Non Contact Radar Level Calculation
09/07/2013 10:15 PM
The speed of light in a vacuum is constant (2.9979 x 10^8 m/s), but electromagnetic waves travel at different velocities through different media. The principal variables here are the dielectric permittivity and magnetic permeability of the substance that wave is traveling through, because these factors influence the electric and magnetic portions of the wave's propagation. For most applications the dielectric permittivity is the most important factor.
Calculating the time of flight is a simple matter of computing time given distance and velocity. A simple thought experiment is to imagine calculating how long it would take an automobile to travel a given distance at a given speed. Pick some really easy numerical values (e.g. how long to drive 200 km if the car's speed is 50 km/hour) and then see what mathematical expression works to give you the right answer.
The real trick, however, is how to calculate the velocity of the wave given the medium it's traveling through. For this you will need to consult a physics textbook to find a formula relating wave velocity to "c" and to the variables mentioned in the first paragraph.
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
09/08/2013 7:42 AM
Since the refractive index of air at STP is about 1.000293, and the OP refers to "... the empty distance from the top of the Tank to the liquid", there is no real trick here.
Good Answers: 46
09/08/2013 12:58 PM
"Empty" doesn't necessarily mean air at STP. For all we know the process application is measuring liquid butane level.
Besides, the odds are pretty good that this is a homework question, in which case the student needs to have all their assumptions challenged in order to learn the concept thoroughly!
09/10/2013 4:24 AM
1) If it is homework, he should be asking his tutor (or reading the textbooks); CR4 is not the place to ask.
2) Otherwise, if he's allowed anywhere near a tank of liquid butane, we should all stay as far away as possible.
09/09/2013 3:40 AM
What a bizarre thread. Most instrument manufacturers have taken care of these things already, meaning that simply programming the instrument correctly in accordance with the user manual will produce a 0-100% signal over the range of level fluctuations.
Bizarre.
Register to Reply 7 comments
JohnDG (3); lyn (1); PWSlack (1); tonykuphaldt (2)
