Previous in Forum: PHSER Mechanical Integrity Procedure   Next in Forum: Flat Pack Housing - How Can It Be Done Better?
SEW Movigear Internal Componets
09/10/2013 9:59 AM
Any one has an idea on how to see the motor and gear arrangement for the movigear?
poy
Re: SEW Movigear internal componets
09/10/2013 10:07 AM
SEW undoubtedly does, and can probably send you a drawing. Try an online search of the model number.
09/10/2013 10:43 AM
Good idea. The original poster would then discover the telephone number with which further enquiries might be made.
09/10/2013 10:11 AM
You might search these documents....
http://www.sew-eurodrive.com/support/index.php
09/11/2013 3:35 AM
I tried to get to the site but still I can't find the internal components, even if I search by spare part list. I sent them a mail but I have not got a reply yet
poy
Good Answers: 183
Re: SEW Movigear Internal Componets
09/10/2013 2:04 PM
The architecture of the assy indicates that motor and outlet have parallel axes. It is most probable a pair of spur gears with a ratio around 2-3.
09/11/2013 3:51 AM
I agree with you, this implies that the motor has only one bearing at it's DE and the and the output shaft has to bearings at it's DE and NDE. So I think the rotor is directly coupled to the pinion gear shaft since it has no support at the NDE just as in the Ingersol compressor set up as in the pictures below
poy
Good Answers: 183
09/11/2013 10:41 AM
No! I think that for different reasons among which the need for parallelism of the two shafts under load both shafts have 2 bearings. The pinion is on the motor shaft on a cantilever end. For a good specific load distribution along gear width above condition must be respected.
Register to Reply 7 comments
nick name (2); olivinak (2); PWSlack (1); SolarEagle (1); Tornado (1)
