Previous in Forum: Best Software To Calculate Cable Ampacity?   Next in Forum: Protection Relay Testing and Calibration
18 comments
Charge Measurement Instrument
09/11/2013 6:09 AM
I am working on a device which stores charge. i wana know that is there any measuring instrument available in market which can measure the amount charge being stored in my device. The device is almost like a big capacitor ie it have two plates at differnent potentials and r being seprated using dielectric medium.
Re: hello every one
09/11/2013 6:22 AM
Good Answers: 39
Re: hello every one
09/12/2013 1:00 AM
One farad is the value of capacitance that produces a potential of one volt when it has been charged by one coulomb. A coulomb is equal to the amount of charge (electrons) produced by a current of one ampere flowing for one second.
Align culture with nature...
Good Answers: 183
Re: hello every one
09/12/2013 5:38 AM
The reference physical quantity is the Coulomb and the current is defined as Coulomb/time exactly the contrary of what you wrote.
But you gave a hint to the OP how he could measure its charge.
I doubt that he will use it.
Re: hello every one
09/12/2013 9:05 AM
Coulomb = Amp x Time NO?
Good Answers: 183
Re: hello every one
09/12/2013 5:29 PM
As I wrote the Ampere is defined as a Coulomb/second. The basic unit is the Coulomb.
From equation point of view of course it can be used in both directions.
Re: hello every one
09/12/2013 6:16 PM
Yes of course.
Re: Charge Measurement Instrument
09/11/2013 9:22 AM
I'd like to understand how this device is almost different from a capacitor....
09/11/2013 9:26 AM
Same here.
Good Answers: 183
09/11/2013 1:34 PM
What you describe IS a capacitor! I see NO special feature which would justify the word "like".
As far as I know (but fortunately I do not know all) you cannot measure charge directly but you could with available devices define the charge via measurements of other parameters.
Good Answers: 44
09/11/2013 4:24 PM
Is this one of those newfangled Leyden Jars?
That guy is just plain nuts...storing energy...pfft! Whatever...
I suppose you follow those nuts Faraday and Clark too....hogwash, I tells ya!!!
I am working on a new device which uses amber and silk to store charge...ssssh...don't tell!
09/11/2013 11:21 PM
A charge is measured in pico farad or micro farad. Use a farad meter you measure the charge.
09/12/2013 9:12 AM
Since this is a flux capacitor, you will need a (1) flux voltmeter (otherwise known as a voltmeter or potentiometer), and (2) a flux current meter (otherwise known as an ammeter, not an anteater).
If I have to explain how to make the connections, or what the upper voltage limitations are, then you are not qualified to be playing with such a device, and will need to return it to the storage locker at Area 51.
09/12/2013 2:20 PM
Since you are making this device yourself, make the tester also. Put a load on the device and time how long it takes to fully discharge. Then change the dope you are using ( the dieelectric) and try again
Good luck, have fun, don't die
Good Answers: 44
09/12/2013 3:01 PM
Multimeter and a calculator:
http://www.wikihow.com/Measure-Capacitance
Good Answers: 183
09/12/2013 5:31 PM
He wants to measure the "charge" and not the "capacitance".
Good Answers: 44
09/13/2013 11:10 AM
Since the OP stated "...The device is almost like a big capacitor ie it have two plates at differnent potentials and r being seprated using dielectric medium" I had to infer and extrapolate for myself.
If you would have checked the link I provided, you would see that the first step provides charge, in Coulombs.
I provided a link with steps and measuring instruments to use...just like the OP asked. I didn't just provide theory and technical corrections to other posts which would probably confuse them anyway...
Good Answers: 34
09/12/2013 9:08 PM
Inderpal,
Most of Multi-meters available in the market can measure Capacitance and DC Voltage.
Measure capacitance of your device, say = C Farad.
Measure voltage across terminals after storing the charge, say =V volts.
Charge Q = C multiply V.
Units of charge calculated shall be in Coulomb
If your device is with single terminal then place it on some insulator (say dry wood), store your charge and measure DC voltage between the charging terminal and the Can or Body of the vessel of your device.
A word of Caution: Such device can build up any level of Static Voltage - which can reach dangerous level.
In case you are trying to store static charge from clouds, by keeping your device on roof top and projecting a solid conductor out with sharp pointer on top edge, be careful, the voltage build up due to charge can reach a dangerous level.
Further, I do not know how big is this device, if you forget your big device on roof and next cloud is of different polarity, then there can be flashover like a lightning strike - do experiment or play with electricity if you please understand it fully.
Shunt your device with Metal Oxide Varister (MOV) if you want to keep voltage to low level say up to 1000V DC.
For higher voltage use calibrated sphere gap.
Best of luck
Register to Reply 18 comments
Anonymous Poster (1); ci139 (1); cuba_pete (3); James Stewart (1); justthecowboy (1); LAA_Lucke (2); Milhan (1); nick name (4); ormondotvos (1); powersolutionsFBD (1); PWSlack (1); Tornado (1)
