Previous in Forum: Pipe Internal Pressure Calculating   Next in Forum: Fab Drawings for Stevenson Fog Bell Apparatus
10 comments
Indian Boiler Regulation (IBR) for CRYOGENIC Steam Heated Vaporisers
09/18/2013 11:30 AM
Dear Friends,
we have an atmospheric open water bath container (approx. 25 m³). We direct heat the waterbath with a simple 3" steam lance (pipe with mulitple 6 mm holes). Before the lance we have a control valve. The steam operating pressure is approx. 4.5 kg/cm²a while the design pressure is 8.1 kg/cm²g.
At the first step we assumed that IBR is applicable up to the control valve. However, in discussion it came up that, due to back pressure (if above 3.5 kg/cm² g) in the lance the whole atmopheric open water container including any down stream piping will fall under the rules of IBR. And addionally the cryogenic liquid coils.
I ask for recommendations how to fix the limits of IBR and if applicable how to design a atmopheric open equipment acc. to IBR.
Are there any ideas how to avoid IBR downstream the control valve?
Thanks for your reply.
Good Answers: 104
Re: Indian Boiler Regulation (IBR) for CRYOGENIC Steam Heated Vaporisers
09/18/2013 12:43 PM
Reduce the back pressure in the lance? Possibly by reducing the flow rate. If I correctly deduce your system, the liquid coils probably still fall under some pressure code.
09/19/2013 2:20 AM
Liquid Coils will be acc. to ASME.
09/18/2013 4:43 PM
You should be asking about downstream of the lance perforations.
09/18/2013 5:16 PM
Larger/more holes in the lance?
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
09/19/2013 2:28 AM
Change the number/size of holes will have negative effect to the performance.
09/19/2013 9:33 AM
How?
09/19/2013 2:26 AM
The question is also, what will be limits of IBR if the back pressure under design conditons (8.1 kg/cm²g) can not be reduced below 3.5 kg/cm²g.
Is it only the lance, or is IBR required for the whole waterbath container and if very worst also for the coils for cryogenic liquid.
Thanks again.
09/19/2013 9:36 AM
The back-pressure in the lance is a function of the flowrate and the immersion depth. The delta-P at each nozzle is a function of flowrate and fluid properties; the immersion depth is insignificant.
As far as the Pressure Systems Regulations go in the UK, the lance, being formed of perforated pipe, would be exempt.
Good Answers: 67
09/24/2013 10:22 AM
What it matters to use IBR piping, a few more metres in length in the downstream of control valve? It's a pity question.
Cryogenic liquid coils never fall under IBR. It's generally made of seamless SS316/SS316L pipe.
09/24/2013 11:06 AM
Dear Pritram, thanks for your needful reply.
The attached piping is not the problem. I have more doubts regarding the atmospheric open waterbath container with all the attachments.
Do you have an idea how this will be handled by IBR?
Register to Reply 10 comments
bigg (1); Mike W (1); pritam (1); PWSlack (2); Tornado (1); XALIX (4)
