Previous in Forum: 1500A 3 Phase 4 Wire + Integral Housing Grounding Aluminium Busduct   Next in Forum: Lightning Arrester
9 comments
Capacitor Power Supply for LED Use
09/19/2013 7:21 AM
Please furnish me with circuit diagram of 12 volt 3 amp capacitive power supply system.
Thanks
Re: CAPACITOR POWER SUPPLY FOR LED USE
09/19/2013 7:36 AM
Check with Mr. Google.
09/19/2013 8:32 AM
Shhhhhhhhhhhhhhhhhhhhh! People on here are trying to sleep!
09/19/2013 9:13 AM
Good Answers: 140
Re: Capacitor Power Supply for LED Use
09/19/2013 2:13 PM
That will be $1,759.34 US dollars... kindly remit immediately and the schematic will be emailed to you.
Good Answers: 116
09/19/2013 5:44 PM
A 12 volt battery does not need a circuit diagram. Did you mean capacity or rating, not capacitive?
If you want AC mains input, the simplest circuit is a transformer.
You can connect two LEDs parallel cathode to anode with one ballast resistor or even one LED with ballast resistor (officially LEDs only have, say, 3V reverse voltage rating in the data sheet, but those indicator lamp types I have tried have very little leakage at 25V.
If you want direct current, follow the 12 volt secondary with a rectifier.
If you want DC which is steady, like a battery, you will have to add a filter and a voltage regulator.
I suggest you try searching for "transformer-rectifier" or "electronic circuits" with a web browser, then narrow it down to power supplies.
Many libraries will have elementary textbooks on electronics, there are many electronics magazines which cater for the beginner, ask the librarian for help.
67model
Anonymous Poster #2
09/20/2013 11:21 AM
CR4 ADMIN: Deleted Post Vulgar/Rude/Improper Behavior: This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
09/19/2013 6:26 PM
09/20/2013 12:20 AM
Nothing is free...
09/20/2013 10:19 AM
Buying one will be cheaper in the long run than building one. See your local parts supply house they have them on the shelf.
Register to Reply 9 comments
67model (1); Anonymous Poster (2); LongintheTooth (1); lyn (1); North of 60 (1); PWSlack (1); Simon Wan (1); Tornado (1)
