Previous in Forum: SA 194 - 4 Nuts   Next in Forum: Popping Up of a Spring Loaded Safety Valve
PWHT Requirement
09/23/2013 9:40 PM
Dear All,
I wanna ask regarding requirement of PWHT in ASME VIII Div.1. I do know that if the thickness over than 1.5" (38mm) is mandatory for PWHT. My question is, if i use 38mm plate thickness, do i need to PWHT the vessel or i still have a chance to do only pre-heating on the vessel? Does the code means the mandatory thickness for PWHT > 38mm or >= 38mm?
Pathfinder Tags: pwht
Re: PWHT Requirement
09/23/2013 11:50 PM
1.5" = 38.1 mm. Maybe that will give a hint. Also, you seem to have a copy of the Code. Did it say over 1.5", or equal to and over? Did it say over 38 mm, or equal to and over?
United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Hobbies - Target Shooting - New Member Safety - ESD - New Member Technical Fields - Education - New Member
09/25/2013 8:31 AM
Code specifically says to not mix imperial and metric and that no conversion should be made between the two. I know it's frustrating at times, but don't do it.
Use the imperial section, or use the metric section. Never convert between the two.
-A-
question everything
09/24/2013 2:16 AM
Open ASME Sec-VIII Div-1.Search for UCS-56 table for P1 material PWHT requirements. Read UCS-56, Note: - 2 (a) and 2(b) carefully. It is self explanatory and can be used for general service conditions. However, you have to consider other service requirements as per ASME Sec-VIII Div-1 (Eg. Lethal service & Impact requirement) for a detailed analysis before a conclusion.
09/25/2013 7:12 AM
yes For p number 1 note no 2-b it is clerly speicfy that for welded joint over 11/4(32 mm) nominal thickness through 11/2(38mm)nominal thickness unless preheat is applied at Minimum Temperature of 200 F(95 C) during welding.
09/24/2013 11:19 PM
Which is more important to you - getting the part finished rapidly and out the door, or getting a reliable quality part?
-A- (1); dkwarner (1); hiesh (1); sanweld (1); Tornado (1)
