Previous in Forum: Cable Type for Connecting Battery Charger to Battery   Next in Forum: Unearthing of VFD Transformer Star Point
ETAP Load Flow
09/24/2013 5:16 AM
Hello,
while running load flow (NR method) with two generaotors, the result doesn't match with hand calculated result. I also tried with matlab. The result from etap is totally different. The problem may be that, during load flow the bus voltage and active power at generator bus are not fixed at prespecified value. The active power is getting zero and voltage is dropping to marginal alert level. I tried using different modes of operation (MVAR control, voltage control, PF control). But, the result is always the same (except MVAR control). How can I overcome this problem?
Thnks in advance.
Pathfinder Tags: ETAP Load flow
Re: ETAP load flow
09/24/2013 9:07 AM
Re: ETAP load flow
09/24/2013 10:24 AM
was it a sarcasm?
Anyway, my matlab skill is decent enough to perform load flow analysis by NR method. There is nothing wrong with matlab code. I tried different networks. The probelm arises only when two or more generaotrs are used. I might be doing something wrong in ETAP. I would appreciate any help or advice regarding that.
Re: ETAP load flow
09/24/2013 11:13 AM
Well, it can't be seen from here, so a local tutor would seem to be a reasonable, non-sarcastic, solution.
Register to Reply 3 comments
lyn (1); nawshad (1); PWSlack (1)
