Previous in Forum: Hello Every One - Question About Transformers   Next in Forum: Indian Earthing System
8 comments
UPS Battery to Install in MCC/Distribution Board Room
09/25/2013 2:13 AM
Can any one give some ides if SMF battery can be installed in AC MCC/DB room
Thanks
BNDas
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
Re: UPS battery to install in MCC/Distribution board room
09/25/2013 3:17 AM
I dont know Indian standard, however this is a standard use in the USA - assuming voltages under 600v.
BSEE but always learning
09/25/2013 3:36 AM
Not without carrying out an acronymectomy first.
09/25/2013 4:03 AM
OK
Good Answers: 44
Re: UPS Battery to Install in MCC/Distribution Board Room
09/25/2013 9:50 AM
Yes, they can.
Specifically, I have an APC Symmetra installed right alongside my switchgear.
However, code and AHJ may still require an extraction hood. I have one.
Good Answers: 804
09/25/2013 2:22 PM
Really? I've heard this before, so I guess the AHJs are not accepting that SMF batteries do not vent then? I wonder if they are ASSuming that they are VRLA?
For the acronym haters, SMF = Sealed Maintenance Free, VRLA = Valve Regulated Lead Acid. VRLA batteries vent hydrogen gas in small quantities, SMF do not.
09/26/2013 3:03 PM
unless the case cracks during failure.
Engineering Fields - Systems Engineering - Member for some time now, see my profile.
09/29/2013 12:34 PM
JRaef
Thanks for the decode, I wass reaching for a couple of books to understand and your clarification came right down the spike.
Thanks
Sleepy
Good Answers: 44
10/01/2013 10:01 AM
My APC USP units at work haven't gassed out, but I ran an Optima in my Jeep to the point of frustration. It got pretty round and the pressure reliefs were spewing some pretty nasty gasses. So, though not a regular occurrence (like my previous wet lead acid units), the possiblity exists.
Our AHJ is NAVFAC. Rules and regs vary.
That Optima was good for another 15 months before it finally wouldn't hold a charge, btw.
Register to Reply 8 comments
1capybara (1); cuba_pete (2); JRaef (1); lrsheldon (1); lyn (1); PWSlack (1); Sleepy (1)
