Previous in Forum: Indian Earthing System   Next in Forum: Induction Furnace
9 comments
High Voltage Electric Motor Modelling and Simulation
09/26/2013 12:05 AM
Hi All and thanks in advance
I wanted to know if anyone knows of a modelling/simulation software package to analyse operation and faults on high voltage electric motors. I wanted to be able to model characteristics of a motor (From known data) then apply a fault either in the motor or the supply and simulate what the effect of that fault would be in say other phases if one phase was shorted. Would like to be pointed in the right direction.
Thanks
Aurelio
Pathfinder Tags: High Voltage Electric Motors
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
Re: High Voltage Elctric Motor Modelling and Simulation
09/26/2013 12:21 AM
A symmetrical components question!
BSEE but always learning
09/26/2013 3:07 AM
If one phase were shorted, then the circuit protective device would operate, thereby disconnecting the supply and stopping the motor.
One doesn't need simulation software to predict that!
09/26/2013 5:11 AM
is OP thinking of SPICE or ETAB or ???
Good Answers: 444
09/26/2013 3:09 PM
Donkey,
SPICE stands for "Simulation Program with Integrated Circuit Emphasis", kind of useless for single line to ground faults in electric power systems... The other program is not ETAB, but ETAP, which is one of the programs that OP would have discovered through a simple Google search..
09/26/2013 5:24 AM
The right direction is red-yellow-blue. The counter-right direction is blue-yellow-red.
Good Answers: 42
09/26/2013 6:02 AM
You could try Yellow-Red-Blue [if you like Kandinsky] or
see [for instance]:
ftp://ftp.unicauca.edu.co/Documentos_Publicos/Facultades/FIET/DEIC/Materias/Control%20de%20maquinas/Charlas/005-estimacion%20de%20parametros/EstimParam/induuction%20motor%20test.pdf
or[better]: Google "Modeling induction motors".
Julius
09/26/2013 9:26 AM
Google it.
Re: High Voltage Electric Motor Modelling and Simulation
09/26/2013 1:12 PM
I know there is a company called Amatrol that has simulators for all kinds of training. They have online multimedia and also training equipment that has troubleshooting software. I have provided a link below and you can inquire about it if it fits your needs. Good luck!
www.amatrol.com/program/industrial-maintenance/
Good Answers: 183
10/05/2013 6:29 AM
Infolytica, femm and other free or not free e-motor simulation packs
Register to Reply 9 comments
1capybara (2); 7anoter4 (1); lyn (1); nick name (1); PWSlack (2); RAMConsult (1); ~~~Phyllis~~~ (1)
