Previous in Forum: High Voltage Electric Motor Modelling and Simulation   Next in Forum: Electro Magnetic Radiation
11 comments
Induction Furnace
09/26/2013 10:34 AM
I am working as electrical engineer in a steel manufacturing plant. in here seven ton induction furnace using for melting. The furnace has been alternatly puncturing. I invite replies for this problem
Re: INDUCTION FURNACE
09/26/2013 10:54 AM
the furnace manufacturer directly.
09/26/2013 10:59 AM
If the power provided to this furnace has not been tripping the breakers then I believe your job is done.
If the operators of this furnace run the furnace so hot that something punctures then they need better training on how to operate the machine.
If your automation system that is supposed to prevent punctures from happening is failing then you should investigate and understand how this automation is supposed to work first. Then explore if all of the input and output signals of the control system is working properly. You may just find out that the design anticipates whatever is getting punctured to be replaced after N cycles of use and that your cheap cost conscious managers have not replaced this for 10*N cycles.
09/26/2013 11:28 AM
What steps have you, the "electrical engineer" taken to investigate and solve this problem, and why do you think that strangers who have no knowledge of the age, brand, operating parameters, nor the competence of the engineering staff or operator's training or process guides can solve this ill-defined problem for you.
Hire a consultant who knows about furnaces and sponge iron for making steel in induction furnaces!!!!!!!
Re: Induction Furnace
09/26/2013 1:06 PM
INCREASE THE OVER LOAD CAPACITY OF BREAKER OR READ MANUAL
Register to Reply Off Topic (Score 10)
09/26/2013 1:15 PM
NO!
One should NEVER just increase the over load capacity of a breaker without analyzing the circumstances. A qualified individual must examine the cabling used and the root cause of why the breaker trips.
09/26/2013 1:55 PM
Wear PPE if you do increase overload capacity. Or use a remote closer.
09/27/2013 5:38 AM
Do make sure that every other CR4 reader is out of the building first!
09/26/2013 11:38 PM
Thank's for every one, Actually iam a beginer in this field. I just compleated my engineering degree in last year. Also actually my interested area is in construction field . But the situation is made me as a furnace engineer. And the management and technisions in this compamy have not enough knowledge about the technical details of the furnace . and the technitions are not ready to show the actuall drawing for me becoz of their ego problem
. So Ikindly reqquest any one to give me brief technical knowledge of induction furnace with necessary drawing and figure. May god will bless you...
09/26/2013 11:56 PM
Start at the beginning.
Induction furnace - Wikipedia, the free encyclopedia
Induction Furnaces - Basics of Foundry Melting Furnaces
ELECTRIC INDUCTION FURNACE
Learn to use a search engine as your tutor.
How to Search the Internet - Southern Oregon University
Don't expect strangers to give you an education. They will help you after you learn the basics.
09/27/2013 12:28 AM
basic principle of a transformer, secondary side is a single turn of molten metal with high amps keeping it at that state.May use water cooling and lots of safety interlocks.
Good Answers: 181
09/28/2013 6:40 AM
It would help if we knew the make and type of furnace.
Seven tons is a bit on the small side for me.
Register to Reply 11 comments
eltech (1); kumarkanurI (1); lyn (3); MUHAMMED SALIH C A (1); PWSlack (2); redfred (2); TonyS (1)
