Previous in Forum: How to Calculate Pressure for Rectangular Tank   Next in Forum: Solar Electrical Bicycle
12 comments
Fixed Center of Gravity for an Object Which Changes its Weight
09/28/2013 7:12 AM
lets say a body of mass M and it has center of gravity at point C
Now when i change its mass to M2, the center of gravity changes to C2
the question is, to maintain the center of gravity for change in mass, what kind of steps can be done?
loves learning........ do u love to teach?????
Re: fixed center of gravity for an object which changes its weight
09/28/2013 7:49 AM
Are you being serious?
09/28/2013 7:54 AM
why?
09/28/2013 8:36 AM
Surely it's obvious from the definition of the centre of gravity, if not intuitively?
09/28/2013 8:01 AM
How does one violate the Conservation of Mass?
Good Answers: 918
09/28/2013 8:16 AM
Let's pretend you have a fish tank that has no appreciable mass. You fill the tank with water and note the system mass and CoG.
Now, you fill the tank with lead (take out the water, first). CoG is the same, but the mass is different.
All you need to do is distribute the new mass exactly as the old mass was distributed.
Was that too hard?
09/28/2013 8:33 AM
He's going to find himself falling over if he doesn't do his own homework.
09/28/2013 10:20 AM
liquid lead or lead bars??
09/28/2013 10:14 AM
Tips for Posting on CR4:
  • Look for answers before you post. Search CR4 or use a search engine to see if you can find the answer to your question.
  • Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
Is this object L shaped? Isn't the homework overdue by now????
09/28/2013 11:01 AM
Here's a good resource to grasp this concept....
http://www.peepandthebigwideworld.com/games/bunnybalance.html
09/28/2013 11:35 AM
But what if part of the mass is relativistic....
09/28/2013 3:00 PM
How does it change its weight?
If by increasing its density, but keeping the same size and shape, no change in CG.
If by adding other weight(s), it depends on their location w.r.t. the original body. In that case, recalculate using normal CG formula.
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
09/29/2013 12:46 AM
Alas, I feel this forum is deteriorating with each passing year!
It is better to fail in originality than to succeed in imitation.
Register to Reply 12 comments
Anonymous Hero (1); dineshjegdeesh (1); Economist (1); Fredski (1); JohnDG (2); kramarat (1); lyn (1); redfred (2); SolarEagle (1); Tornado (1)
