Previous in Forum: DP Type Level Measurement   Next in Forum: Lag Length VS Extension Length for Thermowell
Instrument Drain
10/03/2013 10:45 PM
I need a help from you guys, We have a project in offshore where all pressure instrument drain / vent port are connected to drain header with a 1/4 inch tube, let me know why is that connection required.
Pathfinder Tags: instrument drain
Re: Instrument Drain
10/03/2013 10:51 PM
If you have to ask, there's no hope for you.
Let's do this.
Why do you think all drains are hooked to a common header?
Back to you. Give this a little thought. Where would they drain otherwise?
10/04/2013 12:57 AM
Spill prevention! Guess what happens when it all goes where it wants!
Complacency by not connecting the drains properly can have serious consequences, so keep going!
10/04/2013 3:19 AM
Well, where would the stuff in those lines piddle out to if there were no common drain manifold, then? Does the facility want oil all over the floor (rhetorical question - NNTR)?
Good Answers: 266
10/04/2013 7:28 AM
How about the EPA and OSHA.
Register to Reply 4 comments
IdeaSmith (1); lyn (1); ozzb (1); PWSlack (1)
