So, I've got this big capacitor bank. 8x 330v, with 4x 80uF and other 4 at 120uF. Is it the voltage that creates the stronger magnetic field, or is it the raw energy output? Correct me if I'm wrong, but doesn't amperage just determine how fast the energy goes through the coil? I'd assume that the coil has a significant resistance. So, Ohm's law would dictate that the voltage would increase as the current encounters the resistance from the coil. Am I correct? Or am I missing something.
I just can't accelerate the projectile fast enough, I don't think that magnetic permeability would be an issue at this small scale application.
Using E=1/2CV2 wouldnt that mean that my output is at about 87J? Am I using the equation correctly?
If It is the raw output of the capacitors that would determine the strength of the field, then where the heck can I find a decent ultracapacitor for under $20?
In reply to #99
Find in discussion
