Previous in Forum: Anybody Here from Molokai?   Next in Forum: Good News in the F-35 Program?
49 comments
Good Answers: 16
What Are the Current "Best" Things in Your Toolbox?
10/12/2013 9:14 PM
For me ....
A cheap 14.4v lithium ion cordless drill (1 year old)
A long shaft phillips screwdriver (About 2 years)
A Mitutoyo set of measuring calipers (44 years and still have the box
DY
Good Answers: 203
Re: What are the current 'best' things in your toolbox?
10/12/2013 10:05 PM
Don from Oz:
10" Channel lock pliers
10" Channel Lock parrot jaw pliers
#2 Phillips screw driver
10 in one screwdriver
Channel lock diagonal cutters with strip notches for #12 and #14 wire
Small wire cutters
Scratch awl
Clamp on multi-meter
20 oz claw hammer
20 oz ball peen hammer
4" slotted insulated shaft screwdriver
8" adjustable wrench
Combination wrench set, 3/8" ---> 3/4"
roll of black electrical tape
3/4" x 15 ft tape measure and folding rule with outside extension
vise grip pliers
Most, but not all, 15-25 years old. Some sentimental favorites not used that often.
Good Luck, Old Salt
Good Answers: 141
10/12/2013 10:38 PM
Beer bottle opener. Eventually with some other leatherman attributes.
Plenty of room here
10/12/2013 11:01 PM
Most useful is the multimeter, phillips and straight edge screwdrivers, channel locks, flashlight 18v, 5/16 nutdriver, 1/4 nutdriver, infrared, laser guided, remote temp sensor gun, 4 lb sledge, clamp-on ampprobe, capacitor tester, and the list goes on, almost without end....
10/13/2013 12:32 AM
Black and Decker Power file. You can sharpen just about anything, grind just about anything, drill a hole in the wall and many more, just brilliant.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
10/13/2013 5:31 AM
all the right bits for the Makita: square drive, star drive, big and little phillips, big and little flat blade, allen bits....
BSEE but always learning
Good Answers: 141
Re: What Are the Current "Best" Things in Your Toolbox?
10/13/2013 9:28 PM
What is the meaning of this? I need 25 toolboxes, each one for specific jobs, and another 40 empty toolboxes that I can fill up from the basements, workshops, garages, shacks when I go for a work trip, hoping it fits in one van. And unloading everything afterwards is a pain in the underworld.
Plenty of room here
Good Answers: 16
10/13/2013 9:36 PM
Obviously you have lots of the 'best stuff' ... or maybe your van is your best toolbox?
DY
Good Answers: 102
10/16/2013 7:33 AM
Putting everything back where it belongs after a job is a total pain....agreed.
All those different tool requirements for different jobs is real enough and then you pick and choose and eventually one's work truck becomes a man-purse on wheels.
So really my toolbox is my truck and my truck is the best thing in my "toolbox".
It's my mobile, airconditioned office cum store room. Life support and refuge.
10/16/2013 8:01 AM
it' also not forgettimg to pack in the special tools - i had to fetch once such in record time (say i forgot) from behind 270 km ];T
ci139
10/13/2013 11:50 PM
5 ounce hammer! Big enough for the small stuff and small enough for the big stuff!
If you have none you are screwed!
10/14/2013 3:39 AM
A mallet, handed down from a grandparent. Still going strong after 85 years, albeit with two new heads and three new handles along the way.
Good Answers: 16
10/14/2013 3:55 AM
Hammers of varying sizes and age seem to be winning!
What does that say about us and our use of the 'Irish screwdriver' when all else fails?
DY
10/14/2013 6:30 AM
Continuous or smooth ratchet screwdrivers (no clicks; just turns one way not the other). I have a long shafted and a short "T" handled one.
United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Hobbies - Target Shooting - New Member Safety - ESD - New Member Technical Fields - Education - New Member
10/14/2013 8:36 AM
Beam Clamps
Sorting Bins
Air Conditioner
Sturdy Work Table
Small Vice (8 lb?)
Shop Apron
30+ years of Shop Experience in Fabrication and Tinkering
Tools
question everything
10/16/2013 9:23 AM
You have an Air Conditioner in your toolbox?
Is that a folding table?
I like the way u dress!
I think that 30+ years weight its down!
Never seen tools in a Toolbox, u sure abutt that?
10/14/2013 9:19 AM
ci139
10/14/2013 2:36 PM
There are of course many interpretations of "Best".
In terms of longevity of electric tools, this is pretty hard to beat. It was given to me as a really major Christmas present in 1951, when I was 11. At 250 Watts, it's too big for most of the stuff I work on these days, but when I need the power, it really does the job! I use it as a magnetizer/demagnetizer almost as much as a soldering gun:
I still have at least one commercial spare tip for it, and have made several special-purpose ones over the years. The physics is far superior to the more common Weller style, where the tip is the thickest part, so heat has to conduct from the thinner part into the tip.
10/14/2013 4:05 PM
" best " being most useful
a 225mhz HP scope
large modified set of Xelite tools
left hand drill/extractors #6 through 1/2 in.
300w Wen soldering gun & t/c soldering pen w/vacuum solder sucker
various jewelers type needle nose pliers & hemostats
3/8 reversible drill/driver w/settable torque clutch
small butane jet torch
meerschaum and cherry tobacco
home made pemmican/jerky for break/emergency
10/15/2013 5:03 AM
My ignorance never ceases to amaze me: I've never heard of pemmican before.
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
10/15/2013 7:09 AM
The number 1 best item im my tool box is a magnet on a stick
Nothing is fool-proof to a talented fool
10/16/2013 9:27 AM
That must be to fish the second best tool out from that very large box, isnt it?
Do you have AirCon in there?
Good Answers: 27
10/16/2013 10:18 AM
Actually I suffer from "fat finger" disease and am always dropping that crucial screw/nut/washer in the most difficult locations...
10/17/2013 1:41 AM
Yankee driver with 1/4" hex adapter
Various sizes of stilsons
And the obligatory range of hammers & mallets
The internet, 'cos if I don't know how to do it now, I will by the time I'm finished!
Madness is all in the mind
Good Answers: 104
10/17/2013 8:44 AM
You mean a real Yankee screwdriver? The real predecessor to the cordless drill? Boy, the times I wished I had the one my dad had when I was a kid. No battery to run down or wear out. Never thought about a hex (or 1/4 square) drive adapter for one.
The most useful single item in my toolbox is a $3 multi-bit driver from Tractor Supply. It has a holster with screwdriver bits (2 straight, 2 Philips, 2 or 3 hex), square drive adapter and 4 or 5 sockets, and they all fit tight enough into the holster that I haven't lost one yet. And it's decent quality. I bought 3 or 4 and gave all but one away. (Wish I had bought and kept more now.)
10/17/2013 3:43 PM
Yes, a 131A. Adaptor.
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
10/17/2013 10:20 PM
My Lupenbrille mit LED
(And, of course, my reading glasses.)
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
10/17/2013 11:36 PM
Now that you mention reading glasses, I have to say that the most essential thing in any one of my toolboxes is my AO loupe. I have five pairs distributed between home, shop, the car, and work, in 5x and 7x magnifications.
10/18/2013 5:03 AM
AO loupe?
I realise a loupe is a magnifying glass but what's the AO bit mean?
I have several pairs of 3x glasses from "poundland" (dollar_fifty_land) around but sometimes I need a bit more magnification, and, just stronger glasses would cause my nose to interfere with the work.
Good Answers: 104
10/18/2013 8:35 AM
You ain't from around here, are 'ya? All us 'muricans (hillbillyslang for Americans) know that stands for American Optical, an eyewear manufacturer. Ain't this world a funny place?
10/18/2013 11:02 AM
Thanks!
10/18/2013 3:24 PM
Do they have a version of 'Harbor Freight' in merry old England? They have a headband with lenses with a focal length of about 18 inches for a couple of bucks and their 'Pittsburg' tool line seems to be as good as Craftsman. I bought a bundle of their wrenches (3/8"-1") for $12 (seems to be regular price).
Good Answers: 104
10/18/2013 8:55 PM
I wouldn't make that blanket statement. I have my share of Harbor Freight stuff, including Pittsburgh. Some of it is pretty good, some of it is good enough for homeowner use, and some of it should be sold for scrap only. You have to be careful.
10/19/2013 12:04 AM
I too have a couple of items from HF, but everything I can think of at the moment that came from HF required some finish work before real use.
For me it's a last resort source, when I can't find what I need anywhere else.
I prefer to pay more and get higher quality when possible. I willingly pay as much as double if its made in USA!
Good Answers: 16
10/19/2013 11:47 AM
Filling your tool box with 'locally made' stuff is a worldwide practice. It comes down to your definition of quality .... here are some 'observations'.
UK - value for money
French - has to be expensive
German - precision
Japan - has to be perfect
USA - it has to work
China - need 2 or more examples to compare and decide
Australia - it depends on the strength of the relationship, if I like you a lot, you can sell me rubbish and I will accept as quality'.
DY
10/19/2013 12:28 PM
I generally agree with your assessments, except the last one. ... well maybe if the salesperson is of the opposite sex and really ... .
You just made me realize: I don't think I've ever seen a tool marked "Made in Australia". Is there a reason other than shipping costs?
Good Answers: 102
10/20/2013 4:50 AM
Never seen a Sidchrome spanner?
Good Answers: 102
10/20/2013 4:46 AM
Taiwan- close to japanese quality at a little more than chinese price
10/18/2013 6:01 PM
Correct, except that American Optical makes a whole lot of quality optical instruments other than just eyewear.
I've tried a number of cheaper ones, but I always give those away and go back to quality. For those that might not know, they look like this (lifted to show head band):
Good Answers: 21
10/18/2013 9:21 PM
Check Book! Hire it done. No time for tools, wife, kids, airplanes or sleeping.
Good Answers: 102
10/20/2013 4:55 AM
Best thing in my "toolbox" is a fat wodge of wonga. Best lube in the world.
10/20/2013 9:42 AM
Never heard of Sidchrome; I have only the slightest idea what a wodge may be, and that only because you imply that it is a quantity of wonga, which must be a solid lubricant of some kind. FWIW, my spell-checker knows wodge, but not wonga.
10/22/2013 8:35 AM
My find on the internets. Might be true?
From the Romany word wanger (coal); "coal" was also used as a slang term for money in England in the 18th and 19th century.
wonga (uncountable)
1. (slang, British, chiefly London, New Zealand) money.
"A whole wodge of wonga."
-A-
question everything
10/22/2013 12:38 PM
Ah! Thanks! Now I understand what kind of 'lube' he was talking about...
I was totally ignorant on the subject!
Good Answers: 102
10/23/2013 3:44 AM
Thanks for educating others here on antipodean vernacular.
I tried posting a link to the Collins Dictionary definition but it didn't make it due to some CR4 posting problem which seems to have now been resolved. I was too slack to try again figuring someone else might actually look it up....
Good to see that it got some folk curious.
Wonga makes the world go around. That's how slippery it is.
Good Answers: 16
10/23/2013 8:51 AM
A wonga web check also adds a bird to the list (that includes 'booty') in the toolbox. It maybe stretching the "current best things" to have cash/treasure/lube in the box and a curvacious girl sitting on the cover, but is does sound like a pretty reasonable package to carry around in the can ... err van!
But what would I know about such things ... I'm just an engineer?
DY
10/21/2013 4:14 PM
'Best lube in the world.' Wonga? is that anything like 'Astroglide'?
Good Answers: 16
10/20/2013 1:23 PM
Sidchrome is like an ozzie Kinchrome ...
Yep .. you got me on the wonga too! I doubt you meant a payday lender in the UK but those guys can be greasy!
DY
Good Answers: 16
10/24/2013 10:04 AM
Ken (in his wheel chair) and Rose of Wonnerup, Western Australia
have obviously discovered something in their tool box and done
something about it. Enjoy!
DY
10/24/2013 8:47 PM
What a wrenching display of art!
Register to Reply 49 comments
-A- (2); 1capybara (1); Anonymous Poster (1); bigg (3); Bricktop (1); bwilko (1); ci139 (2); dkwarner (8); Don from Oz (6); dvmdsc (2); fixitorelse (1); geraldpaxton (2); GM1964 (2); IdeaSmith (3); lonster (2); old salt (1); PWSlack (1); Randall (4); SolarEagle (1); Wal (5)
