Previous in Forum: Signal EMI protection   Next in Forum: Parallel or Series Magnetic Coils?
Basic theory on servo and/or step motor.
06/06/2007 10:57 AM
Hello everybody. Anyone knows where can I find basic theory about Servo Motors and/or Step Motors? I would like to know what kind of gear is more suitable for high torque, high speed and high control for, let's say, robotic's arms motion.
Thanks in advance.
Good Answers: 97
Re: Basic theory on servo and/or step motor.
06/06/2007 6:00 PM
You should visit a guru www.galilmc.com
06/07/2007 11:07 PM
I'm going to say that a well-executed servomotor system will provide more power, smoother, quieter and higher performance motion control than a stepper of the same size/weight. Not to say there aren't appropriate places for a stepper system. Quantity would drive part of the decision.
Gearing is an interesting question; its a key, key, read:important piece of this system since it puts a lot of potentially painful variables between your actuator (the motor) and the load (the robot arm). I could well imagine different types of gearing in the system; some kind of planetary, relatively high ratio box on the motor driving a rack&pinion on the arm.... Feedback sensors on the motor and the load, 2 control loops, etc.
Harmonic gears might work, but they're very high ratio and you haven't given any information as to the (multiple) definition(s) of "high" in your original query. There is a pile of information that needs to be filled in, in order that a sensible system could be designed and executed.
Hugh
06/08/2007 8:30 AM
Try searching at google .. Servo Motors in pdf
The use of word pdf will provide you tons of info and can also help you in future research
Jhun
Good Answers: 18
06/08/2007 9:02 AM
Good Answers: 18
06/08/2007 9:12 AM
Ah . . . Finally found a source for a book put out by Electro-Craft Corp. several years ago: http://www.directtextbook.com/publisher/electro-craft This is one of the best texts on motors and servo systems I have ever run across.
Galil, which Hendrik mentioned in his post, is also a good source of information, and it's on-line.
Bill (2); Hendrik (1); hughv (1); mechanical (1)
You might be interested in: DC Motors, Servo Valves, Servo Drives
