Previous in Forum: Storing Battery Over Winter   Next in Forum: Specification of softstarter for 335hp miil motor
12 comments
Three Phase Synchronous Generator
10/23/2013 9:52 AM
What could b the cause of abnormal sound coming from a three phase synchronous generator when voltage is building up during starting up?
Re: Three Phase Synchronous Generator
10/23/2013 10:18 AM
Mechanic still working in back.....? Maybe bearings ...? cat sleeping on warm motor....?
https://www.youtube.com/watch?v=pwvS8_H5rKs
10/23/2013 4:49 PM
Great video!
10/23/2013 10:54 AM
  • Budgie caught in the works
  • Someone left a spanner inside it when it was boxed-up
  • Mounting bolts loose/broken/missing
  • Too little sound insulation in the building for some reason
  • It's flooded with water
  • Wrong fuel
  • It has just run out of fuel
  • Landslide dropping onto it
  • Aircraft crashing into it
  • Terrorist caught inside it
  • Etc., etc.
10/23/2013 11:58 AM
  • Bent blade on the cooling fan striking the cowling
  • Loose cable connection onto the terminals
  • Loose materials underneath it
  • Water in the fuel
  • Rotor shaft snapped off
  • Blown head gasket
  • Coolant pump knackered
  • Electrician still connected to the terminals
  • Bent security cover with rattling padlock
  • It isn't level in accordance with the set-up detail in the User Manual
  • Mechanical overload
  • Electrical overload
  • It doesn't know the tune
  • Etc.
10/23/2013 12:00 PM
  • Blown silencer/muffler
  • Rattling control panel
Is there a prize for getting the right answer?
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
10/24/2013 10:43 AM
  • Electrician still connected to the terminals I'd call THAT an abnormal sound!
Good Answers: 181
10/24/2013 12:28 AM
Quite simple, something's wrong.
If you ask a stupid question you get a stupid answer!
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
10/24/2013 1:56 AM
is it a funny noise coming from the left side below that red panel?
BSEE but always learning
10/24/2013 8:52 AM
Did you push the BLUE button??? You should NEVER push the BLUE button!
10/24/2013 10:41 AM
But blue is my favorite colour, not yellow . . . . A - a - a - a - a - a - r - g - h
10/24/2013 1:33 PM
I vote this as being the dumbest question winner for 2013.
10/25/2013 2:51 AM
its some imbalanced thing or a bad bearing. and the solution is to fix bad bearings or balance what is not.
Register to Reply 12 comments
1capybara (2); Andy Germany (1); Brave Sir Robin (1); JCase (1); PWSlack (4); SolarEagle (1); Tom_Consulting (1); TonyS (1)
