Previous in Forum: Three Phase Synchronous Generator   Next in Forum: Can I Use 50Hz Motor on 60Hz?
13 comments
Specification of softstarter for 335hp miil motor
10/24/2013 3:19 AM
please provide the specification softstarter of 335 HP mill motor
Re: Specification of softstarter for 335hp miil motor
10/24/2013 3:46 AM
Please provide specification of motor.
Start with name plate details maybe!
10/24/2013 4:07 AM
Please provide the supply power information.
10/24/2013 4:20 AM
Please state whether the motor starts under load or not.
Good Answers: 181
10/24/2013 9:53 PM
Every mill I've worked on was pre loaded.
It would normally be on load starting.
Given the scant information, who knows what the real start conditions are.
10/24/2013 4:21 AM
Please give details of the load.
10/24/2013 5:52 AM
its a pellet mill motor
10/24/2013 7:34 AM
OK. Keep going. Everything will turn out fine.
What else is known about it?
10/24/2013 4:22 AM
Please state the expected range of ambient temperatures.
10/24/2013 11:49 AM
Please state the cable size and the termination lug size.
Good Answers: 804
10/24/2013 12:29 PM
What is the size of the transformer or generator feeding it?
How much voltage drop can you tolerate on the supply when you start it?
What kind of environment is the soft starter going to be mounted in and how would the heat output of the starter affect that decision?
10/24/2013 2:26 PM
This is like pulling teeth.
Hire an electrician if you don't know what you are doing.
10/25/2013 1:08 AM
Hire a dentist would make more sense here!
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
10/25/2013 6:26 AM
^ ^ GA ! ^ ^
BSEE but always learning
Register to Reply 13 comments
1capybara (1); IdeaSmith (2); jack of all trades (1); JRaef (1); NASRU (1); PWSlack (5); TonyS (1); Tornado (1)
