Previous in Forum: Diesel Generator Issue   Next in Forum: Zero Sequence Generator (Earthing Transformer)
14 comments
Surge Arrester Rating Selection
10/29/2013 2:26 AM
I'd like to know how to select ratings for SA.
Drawing is not so clear.
So I'm adding some more design factors.
- MV SWGR nominal system voltage : 6.9kV, 3P 3W system.
- Unit Transformer is grounded via NGR : 100A, 30sec
Also LA for the primary of Step-up Transformer.
Re: Surge Arrester rating selection
10/29/2013 4:04 AM
The posted drawing is practically unreadable here.
Re: Surge Arrester Rating Selection
10/29/2013 2:32 PM
You need an expert, or at least someone with a cursory knowledge of electricity and local codes, to do this for you.
Lightning arrester - Wikipedia, the free encyclopedia
10/29/2013 9:05 PM
http://bayimg.com/IAbAIAAfK
You can see clear image here!!
10/29/2013 10:50 PM
10/30/2013 7:03 AM
That image is practically unreadable as well.
10/31/2013 8:13 AM
By clicking, you can see original size of drawing.(readable)
The reason why I ask for this is as below;
In the project that I am in, Surge arrester(S.A) for 6.9kV(L-L Voltage) Switchgear was selected as 9kV, 5kA.(PDV-65) for feeder and incomer both.
As far as I know, in 4.0kV(Line-Ground Voltage of 6.9kV L-L Voltage) system, S.A rating of 9kV cannot guarantee surge/overvoltage,
because residual voltage(discharge voltage) Ures is 30kV, which is 7.5 times of 4.0kV.
Here is what I sketched for S.A discharge characteristic.
Of course I know, S.A will discharge from 9kV point, but 9kV is fairly high voltage for the equipment, I guess.
Please advise if this S.A rating selection is correct or not?
(overvoltage protection for between 4.0kV and 30kV area)
04/11/2024 10:23 AM
Please identify the local standard against which the <...Surge Arrestor...> in question was selected. The rest of it is second-person-check; is there only one person at the facility who can do that? How peculiar.
10/29/2013 11:56 PM
Dear Mr.posity,
Pl. open the following links one by one and read. I am sure, Definitely you will get you what you are looking for.
In addition to this there is a Han-Book published by IEEE, COMPRISING 1024 pages, the link could not be located, in my system. I will try to get it and post here.
These details are available in the ELECTRICAL ENGINEERS PORTAL and get registered there and you will get mails regularly LIKE CR4 which is ENRICHING OUR KNOWLEDGE and our CR4 MEMBERS share their knowledge, expertise and advise.
http://electrical-engineering-portal.com/download-center/books-and-guides/siemens-basics-of-energy/basics-of-surge-protection
http://electrical-engineering-portal.com/surge-protective-categories-defined-by-ansi-ieee-c62-41
http://www.lightningsafety.com/nlsi_lhm/IEEE_Guide.pdf
http://electrical-engineering-portal.com/surge-protection-of-electronic-equipment
DHAYANANDHAN.S
Good Answers: 170
10/30/2013 12:13 PM
The LA Rated voltage is: Highest System Voltage x Ground Fault Factor
The ground fault factor depends upon the type of system grounding and on the ratio R0/X1 & X0/X1.
10/30/2013 11:49 PM
Thank you Mr.electricalexpert65 for your response. You have mentioned " the ratio R0/X1 & X0/X1.
I request you to Pl.explain the ratio R0/X1 & X0/X1.the ratio R0/X1 & X0/X1.
DHAYANADHAN.S
10/31/2013 10:10 PM
Thank you for your idea sharing.
I think as below;
- Highest System Voltage : peak voltage (√2 x Us /√3 = 5.63kV)
- Ground Fault Factor : According to IEC 60099-5, 1.73 for Impedance Grounding system.
=> LA rated voltage = 5.63kv X 1.73 = 9.75kV ??
Am I correct?
Good Answers: 170
10/31/2013 10:38 PM
LA Rated Voltage is HSV (rms) x GFF
GFF will be 0.8 for effectively grounded systems and 1.732 for ungrounded systems. For impedance grounded systems, GFF will float between these two values of 0.8 & 1.732, depending upon the ratios R0/X1 & Xo/X1 as mentioned by me earlier.
Now, assuming solid earthing in a 11kV system; the HSV for 11kV is 12kV; GFF is 0.8; thus, LA rated voltage is: 12 x 0.8 = 9.6kV; the nearest standard LA one could get in the market is 9kV. Thus, it is 9kV.
But, the case under study is a Low Resistance grounded 6.9kV System. Here, the LA has to be selected duly considering the R0/X1 & X0/X1 ratios only.
Appendix B of IEC 60071-2 throws more light on this. Suggest to go thro the same.
I think, with this I have answered Mr. Dhayanandan (posting 8) too.
11/02/2013 10:29 AM
THANK YOU Mr.Electrical Expert for yor reply.
DHAYANANDHAN.S
11/04/2013 2:15 AM
Thank you very much for your further explaination, electricalexpert65
May I ask one more question?
In IEC 60099-5, Figure 23b, it is saying that " Three-wire impedance earthed systems. Earth Fault Factor 1,73"
So, I thought Maximum voltage between phase and earth would be 1.73 x Us / √3 = 6.89kV.
Once again, I really appreciate your comment.
Really helped me a lot understanding overvoltage.
Register to Reply 14 comments
dhayanandhan (3); electricalexpert65 (2); lyn (2); posity (4); PWSlack (3)
