Previous in Forum: High Velocity Flameless Oxyfuel Burner   Next in Forum: What Would You Do?
10 comments
Fresh Air
10/31/2013 2:39 AM
Frequent emissions from a nearby volcano, when the wind direction chooses, falls close by our small factory building poluting the atmosphere and depositing dust particles inside the premisses I am refurbishing the factory and aim to seal the building securely using conventional building materials. My plan is to introduce filtered air mechanically.to positively pressurise the internal space thus denying non filtered air tracking inside the building. Air volume depicted by available space is 670 cubic meters. My question is how many air changes per hr are required to give the occupants (4-5)a cost effective comfortable environment And what would the effects be to the volume if room air conditioners were installed
User-tagged by 1 user
Good Answers: 21
Re: Fresh air
10/31/2013 3:13 AM
Not knowing local laws and regulations for your area, I would suggest you start there. If you have an agency such as our OSHA, check with them as well. If there are none of these then I would google for an answer. Most times we would like to see 4-5 turns per hour on room air volume. So you can figure fans size from there. P.S. there are systems designed to give ac air with positive pressures so you can just plug and play. Google these as well.
Re: Fresh air
10/31/2013 3:17 AM
Thanks for that 4 to 5 turns per hour is easily achieved, but will wait to see if there are any further comments
Re: Fresh air
10/31/2013 4:26 AM
Air conditioning does not affect the volume of the room.
Needless to say, any aircon needs to operate with filtered air.
<...nearby volcano...> Is the factory in the right location for long-term operation?
Re: Fresh air
10/31/2013 8:43 AM
one good volcanic blast can ruin your entire day, an air filtration system can address the ash component but will do nothing to neutralize the gaseous emissions. you're really biting off a lot here!
Re: Fresh Air
10/31/2013 9:48 AM
The amount of fresh air over and above the status quo would depend on any chemicals being used in the building.....This includes cleaning and other chemicals used on a regular basis....You might consider a staged loading filter system for particulate mitigation....A study on the particulate size and composition would be helpful, so your filter system might be optimized...Filters are expensive, a washable prefilter stage might be the way to go....
Good Answers: 19
Re: Fresh Air
11/01/2013 1:33 PM
SolarEagle is right on the mark here.
First off there is no such thing as Fresh Air a common mistake we all make....it is out side air, as I learned the hard way by saying I would bring in "fresh air" make up into a law office in San Francisco. It ended up fresh air........ with heppa filtration, ionizers, and humidification but it cost me 10k to accomodater the "fresh Air" Clause in my proposal...now I bring in OSA.
Well that rant is over...take a look at these standards they will supply you with the knowledge and answers you need to your question.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&sqi=2&ved=0CCoQFjAA&url=http%3A%2F%2Fwww.ashrae.org%2FFile%2520Library%2FdocLib%2FPublic%2F20060815_200652210714_347.pdf&ei=4-JzUpypM-a2sASJ6oG4BA&usg=AFQjCNEIKAeYuBV-98VHMilFPxKD-eAwJQ&sig2=Gsb-gGaiSFTXVNIjRoU2IA
ASHRAE ADDENDA Ventilation for Acceptable Indoor Air Quality
Have a great day.
Good Answers: 102
Re: Fresh Air
11/01/2013 6:02 AM
You have the figures you asked for. That's good.
BUT.....
Can't you relocate?
Apart from 4 or 5 people what else inside the building would need dust free air?
Filters need cleaning and possibly eventual replacement. Who would do that? Is it really that hard to sweep regularly?
Re: Fresh Air
11/01/2013 6:58 AM
The assumption should be that relocation is not an option, The question addressed a problem about how to adapt. there are disasters happening all over our globe and the popular reaction is to move to greener pastures? This is not a practical solution, Think refugees More better that we learn to adapt The question is How many changes of air would be practical to keep 4 or 5 people comfortable inside a sealed factory building pressurised with filtered air?
Location: Washington (the state), 2 blocks from the Columbia River
Re: Fresh Air
11/01/2013 3:51 PM
As to what else would need fresh air - any machinery inside will. I was under the cloud when Mt St helens blew and the ash we got was two types. One looked like the bubble filled glass insulation after taking a hammer and rolling pin to it. I could hear the little 'tink" as it each particle landed on cars. The second type of ash was like flour and got everywhere; it floated very nicely despite being rock. Both are very abrasive; Some folks wiped that first ash off their car like it was ordinary dirt and ended up with many scrathes to the paint. As a bonus I got the next day off work as a "volcano day".
The reward for a job well done is another job.
Re: Fresh Air
11/06/2013 8:50 PM
Good! Everybody and everything need fresh air!
Register to Reply 10 comments
Caroline.Yuan (1); fixitorelse (1); Fredski (1); geemac4 (2); JL Dowell (1); PWSlack (1); SolarEagle (1); Stedou73ish (1); Wal (1)
