Previous in Forum: Alternator Voltage Frequency Change   Next in Forum: Estimation of Rectifier Capacity
27 comments
Voltage
10/31/2013 10:26 AM
What is the voltage of 198 kW three-phase load with cos FI=0,99 and current 215A?
Re: Voltage
10/31/2013 10:35 AM
Is this a test..?....You guess first......then I will....
Re: Voltage
10/31/2013 10:37 AM
its homework, no doubt
Re: Voltage
10/31/2013 10:44 AM
Not a Test SolarEagle! Just need a friendly favor from YOU
Re: Voltage
10/31/2013 10:35 AM
good question
Re: Voltage
10/31/2013 10:42 AM
so! what is the answer?
Re: Voltage
10/31/2013 10:48 AM
amps*volts=watts
Re: Voltage
10/31/2013 10:49 AM
Is this the answer?
Re: Voltage
10/31/2013 10:50 AM
It's an answer.
Re: Voltage
10/31/2013 10:55 AM
SolarEagle! Another favor
Please answer this
What is the total capacitance of capacitors connected in series, C1=1214F, C2=2121F ? Result must be INTEGER (without -F-)
pleeeeeeeeeease
Good Answers: 69
Re: Voltage
10/31/2013 11:12 AM
The last time I checked, the total capacitance for series capacitors was:
C= 1/(1/C1+1/Cn)
in your example:
C= 1/ (1/1214 + 1/2121) = 1/ (.0008237 + 0.0004714) = 1/0.001295 = 772.0821 F
Can't be an integer
Re: Voltage
10/31/2013 11:15 AM
the last time, the first time, and the second time you checked too
Re: Voltage
10/31/2013 11:14 AM
New Zealand - Member - Kiwi
Good Answers: 29
Re: Voltage
10/31/2013 3:59 PM
Its an answer, but not a correct one.
Watts = Volts x Amps x PF in an AC circuit.
Of course, being a solar guy, the Eagle hasn't ever had to do any AC calcs so his formula is fine for DC applications.
paulusgnome
Re: Voltage
10/31/2013 4:02 PM
You forgot √3 for 3-phase.
Good Answers: 29
Re: Voltage
10/31/2013 4:29 PM
Woops, so I did. I stand corrected.
Type in haste and repent at leisure.
paulusgnome
Re: Voltage
10/31/2013 4:03 PM
he never did AC really?
Re: Voltage
10/31/2013 10:49 AM
Don't be a meanie-bum. Offer a prize for getting the right answer!
Anyway - why not just stick a voltmeter on it and ask that instrument instead?
Re: Voltage
10/31/2013 10:53 AM
Can't , can you do that? Pleeeeeeeeeease
Re: Voltage
10/31/2013 11:05 AM
Just as soon as FedEx (other delivery services are available) gets here with 2*3500 miles of single-conductor voltmeter connector lead.
Presumably it will want a signature?
Oh, and a boat, with supplies and a bed for four nights' Atlantic travel each way while the cables are paid out...
Hang on. Who is paying for all this?
Good Answers: 69
Re: Voltage
10/31/2013 11:23 AM
It's a little tough to get along in here when you're a newby, but don't quit, be patient, you'll figure how to improve (or adapt) your comunication skills; then it will become a highly rewarding experience, this site is really a pond of wisdom.
Hope to see you often
Re: Voltage
01/09/2014 5:15 PM
Charmer!
Good Answers: 804
Re: Voltage
10/31/2013 11:10 AM
You must be in school to get a degree in management, because rather than figuring out the answer, you are trying to coerce someone more competent to do your work for you.
Good luck with that... And by the way here is a hint for you future as an incompetent manager: highly competent people often resent the kind of arrogance you are displaying, so to get back at you, knowing you will take credit for doing the work yourself, they MIGHT consider giving you the wrong answer!
Re: Voltage
10/31/2013 11:18 AM
Come on! Its not like that.
Anyhow, thanks for you respond
Good Day!
Re: Voltage
10/31/2013 7:42 PM
Why don't you just fess up, before I have to out you.
Re: Voltage
10/31/2013 11:21 AM
a suggestion...try starting off with something that sounds like, "I'm a student working on capacitance formulas and I sure could use a little help working out some simple problems, can anyone with a little spare time offer a little help?" you'll get further and Jaef might even put you on his Xmas card list
Re: Voltage
10/31/2013 4:14 PM
W = V A √3 cosφ
Re: Voltage
01/09/2014 5:59 PM
KW = V A √3 cosφ/1000. This can be rearranged and solved. (φ is Greek letter phi.)
Register to Reply 27 comments
Fredski (5); IdeaSmith (1); JC123 (6); JRaef (1); lyn (1); Paulusgnome (2); PWSlack (3); SolarEagle (3); Tornado (3); Yahlasit (2)
