Previous in Forum: Minimum Generator Rating to Sustain a Motor Soft Starter   Next in Forum: ZCT and Nuissance Tripping for EFR Problem
13 comments
Capacitor Fault
11/05/2013 9:51 AM
hi everyone
i face problem that the capacitor have burn in high voltage plant in VFD motor and that is not the first time i see there will be some problem but can not find it..and before four months we have build new generation project so is there any relation between this problem with the new generation
Re: Capacitor Fault
11/05/2013 10:20 AM
Is there anything in the way of specific information available that might help the forum get a start on this?
Re: Capacitor Fault
11/05/2013 10:57 AM
I see exactly your problem.
Re: Capacitor Fault
11/05/2013 11:03 AM
Indeed. That is the problem.
Good Answers: 804
Re: Capacitor Fault
11/05/2013 11:13 AM
Maybe I'm being a spoiler, but is the capacitor at the motor? If so, did you fail to read the instructions that came with the VFD telling you to NEVER put capacitors between the drive and the motor?
And if you had the caps on the line side, why? The VFD will correct the displacement power factor for you, there is no reason for the capacitors and they present a risk of resonance in the circuit with the VFD's DC bus capacitors.
Re: Capacitor Fault
11/05/2013 11:28 AM
...which would explain an overvoltage at the external capacitor, and its early demise. GA.
Re: Capacitor Fault
11/05/2013 11:54 AM
Yep, another likely ESO failure.
Good Answers: 122
Re: Capacitor Fault
11/06/2013 8:49 AM
Good morning JRaef,
Some of our older GE & Toshiba VFD units with analog speed feedback do have capacitors on the motor side of the drive.
The newer vector drives do not.
Maybe the OP is dealing with older equipment.
Good Answers: 804
Re: Capacitor Fault
11/06/2013 12:18 PM
Replying to Comment by SHOCKHISCAN: "Good morning JRaef, Some of our older GE & Toshiba VFD units with analog speed feedback do have capacitors on the motor side of the drive. The newer vector drives do not. Maybe the OP is dealing with older equipment."
Maybe, although this is still suffering from a lack of attention to detail. Most likely you are seeing older Current Source Inverter drives or six step drives that used GTO Thyristors as output power devices, they often needed tuned capacitors on the load side of the drive as part of the necessary circuit design to make the GTOs turn off. That technology is now long gone. Even modern CSI drives no longer use GTO Thyristors.
Good Answers: 804
Re: Capacitor Fault
11/05/2013 11:56 AM
Or another RTFM situation...
Re: Capacitor Fault
11/05/2013 12:35 PM
Or burned by an "energy saving" company/consultant?
Re: Capacitor Fault
11/06/2013 3:18 AM
How about that for global warming?
Re: Capacitor Fault
11/06/2013 4:22 AM
Dear Mr.ibrahim1988,
Your question does not indicate, like Capacity, Whether the Capacitor is before VFD or after VFD, level of Harmonics Filtering, Earting of VFD etc. Pl. give the factual ground reality. Then only CR4 MEMBERS can suggest a remedy.
DHAYANANDHAN.S
Good Answers: 122
Re: Capacitor Fault
11/06/2013 9:04 AM
I would suggest you look carefully at the drive regeneration control circuitry.
The drive must have the means to discharge the high voltage created by the collapsing motor field regeneration when the drive supply power is removed and the motor leads are open-circuited.
If/when this voltage exceeds the insulation rating of the capacitor it will penetrate through and cause the capacitior to fail.
You should have either:
1. A dynamic grid resistor bank that is switched into the motor lead circuit automatically when the drive output contactor is opened.
or
2. The drive circuitry will have regeneration control circuitry that will use the secondary bridge components for dissipation of the voltage.
Start by reviewing the drive instruction manual to identify which type of circuitry is present.
If the drive uses internal regeneration control you must not allow any personnel to attempt repair unless they are fully trained and competent.
Register to Reply 13 comments
dhayanandhan (1); JRaef (3); PWSlack (4); redfred (2); SHOCKHISCAN (2); Tornado (1)
