Previous in Forum: Iron and Iron-Carbide Phase Diagram   Next in Forum: Universal Warming Mars and Earth and NASA
Small ID Tubing
11/14/2013 2:09 AM
I am looking for non-standard rigid polymer tubing, 1mm OD x 0.5mm ID and 1.xx OD x 1.2mm ID. Preferrably straight seeing as they need to be assembly concentrically. Saw some distributers on the web but they are UK based, am looking for a North American supplier.
Thanks,
Philippe Dekleva
Pathfinder Tags: polymer small ID tubing
Re: Small ID tubing
11/14/2013 6:19 AM
Location: OHIO, tri-State design and installation, and travel nationally and consults also are international
pen tubing 2 Re: Small ID Tubing
11/14/2013 8:38 AM
just read
http://www.practicalmachinist.com/vb/general/rigid-small-diameter-plastic-tubing-148682/
Simply choose your utility supplier contracting WITHOUT BROKERS and opt-out of community aggregations for free choices.
Re: Small ID Tubing
11/15/2013 10:39 AM
Try
Professional Plastics: www.proplas.com
Zeus: www.zeusinc.com
Amazon Supply: www.amazonsupply.com
Cole-Parmer: www.coleparmer.com
Teleflex OEM: www.teleflexmedicaloem.com
Can you tell us what material you want to use? May help point to a particular supplier. "Polymer" is pretty broad.
Re: Small ID Tubing
11/15/2013 12:55 PM
Thanks for the links. by polymer I mean rigid, much like PEEK, PMMA, etc. PEEk only comes in 2 OD's which will not work seeing as I need to fit one inside the other with a resulting small annulus between them. I have made similar designs using SS but I cannot use SS for this application
Re: Small ID Tubing
11/15/2013 1:14 PM
I should add that the dimsensions I am needing are .020" ID or metric equivalent, for the inner tube and the area of the annulus roughly the equivalent of a .020" diameter. So it is small tubing/capillary and glass will not work. Also, the tube lengths needed are short, in the neighborhood 1/2" (12-15mm)
Re: Small ID Tubing
11/15/2013 12:52 PM
When I needed some small bore tubing for a laminar flow element, I used heatshrink tubing, as that gives the small bore, thin walls as well as straight semi-rigid tubes.
Easily available most places. John
Good Answers: 123
Re: Small ID Tubing
11/15/2013 1:08 PM
Have you tried US Plastics?
Bob
Register to Reply 7 comments
bob c (1); dekleva (2); Electroman (1); JP76 (1); lyn (1); stringman (1)
