Previous in Forum: MWt Versus MWe   Next in Forum: Issue with Woven Mesh Braking on a Machine and Sensors
21 comments
Water Pump Question
11/22/2013 2:31 AM
Hi all,
I would like to find out what would be the best 110 volt water pump that can pump enough water from a 25' shallow well for a distance of 1400 ft., slightly down hill (about a 20' drop), through a 1" ID buried hose that would be capable of running 3 small rainbirds.
Thanks, Ron
'Consider it all entertainment'
Pathfinder Tags: shallow well Water water pump
Re: water pump question
11/22/2013 4:18 AM
Do you have any data on the gpm for each Rainbird® sprinkler?
11/22/2013 5:48 AM
The power needed by any liquid mover is the pressure difference across it multiplied by the flowrate through it divided by the efficiency.
In this case, the first two pieces of information are not known to the forum, therefore it cannot size the pump nor make recommendations at this time.
11/22/2013 6:07 AM
Tornado has a very good point.
After determining the GPM requirement, and pressure needed for the 3 units, it's simply a matter of looking for a pump that can supply that much water at the required pressure and flow needed.
Be careful when looking at pump specs. Both flow and pressure must be considered.
If pump curves are available, look at them.
Also, remember gravity helps you. You will only have to lift the water 5' effectively since you have 20' of drop also. Then is a matter of considering friction losses over the 1400 foot run.
My guess is something in the 1 HP range would do.
Also if you had 220V service, use it.
TRy some of these, too: Sprinkler systems with pumps
Good luck.
11/22/2013 9:25 AM
Given your distance you may be better off using two pumps working together in a push pull configuration.
A submersible in the well pushing the 1400 feet and a slightly smaller rated jet pump boosting the pressure at the end.
Off the top of my head a 3/4 - 1 HP submersible with a 300+ deadhead rating and a 1/2 - 3/4 hp jet pump boosting the pressure for the sprinklers should give you all around good results.
11/22/2013 10:01 AM
I also wonder about the volume of water that your shallow well can produce at any given time. You might consider using a storage tank.
With this in mind, a windmill pump filling a raised storage tank could eliminate the need for any electric motor driven pump. There are just too many unknowns here to make a single recommendation. The only information I can tell you is that your piping alone will take just over 57 gallons of water to fill it.
Good Answers: 104
11/22/2013 10:54 AM
We had a pretty good discussion on a similar topic here: http://cr4.globalspec.com/thread/56377
As someone else has noted, you need to know the specific rainbird. But as a point of reference if you had a total demand of 8 GPM (2.67 per sprinkler), the pressure loss in the pipe would be about 2 psi/100' (ignoring the down slope, since we don't know what it is) or 28 psi total. If the sprinklers need 30 psi, that gives a total discharge pressure of 58 psi. This is doable with a 1/2 HP submersible pump but might require a 3/4 HP jet pump. I'm using Grainger.com as a reference, again not a recommendation. If the pump will be only used for the sprinklers, you probably don't need a tank.
Again, the earlier post contains some good points to ponder.
11/22/2013 12:25 PM
Down slope is 20' over 1,400'.
Point is the water only has to be lifted 5' effectively. The slope is less than 1°, but, it's still there over the run of pipe.
11/22/2013 1:02 PM
This is part of the reason why I wondered if the shallow well can support the amount of water to be drawn. If there is no water blocking barrier (clay, rock formation) between the well and irrigation location then the water table must no greater than 5' below the irrigation point. Remember also this is a well and not the bottom level of a cistern. Trying to draw more water than the ground will release will not work regardless of the size of the pump. The 5' difference also makes me wonder about when this irrigation system is intended to be used. If it rains so often that a 25' well will always have water, why does a location only 1400' away need irrigation? Certainly this well could be part of an underground stream. But there wold still be a limit of how many gallons per minute could be drawn.
11/22/2013 1:11 PM
Yes, there's a lot we don't know.
In my limited experience with having wells drilled, running a capacity test is fairly standard, so OP may already know this.
That would help him determine if he needs an aux. tank, or not.
11/23/2013 2:07 AM
I have friends who have a similar situation on their property. hey have a stock well which is basically severall 6' dia concrete culvert sections buried in the ground about 20 feet down.
The water table where they are will often times go a foot or better above the surrounding ground yet everything is dry as dust on the ground surface.
There garden is about 300 feet away and they have to pump water to it otherwise nothing grows.
Some years ago we tried pumping the stock well down to see what the refresh rate was and it took my 12,000 GPH pump 2 hours to drain it down and even then it was refreshing itself at close to 100 GPM once I hit the bottom!
Good Answers: 104
11/22/2013 4:50 PM
Oops . Well 20 ft won't make but 10 psi difference. And, it's in his favor.
Re: Water Pump Question
11/22/2013 12:14 PM
without getting into all the math just yet...I assume you're talking basic irrigation here. if so you'll probably want to have your pump fill a storage tank at the site you expect to irrigate. the amount of "feet of head" you'll need to operate your sprinklers will determine the size of your tank and the PSI you'll move your water. so get your sprinkler info and elevation information. then we can make suggestions
11/22/2013 10:00 PM
Since you want to supply water to 3 small rainbird (sprinklers ?), why don't you just go to the www.rainbird,com website and download their Manual on( sprinkler design)?...
11/22/2013 10:17 PM
Uh-Oh! Something Went Wrong!
502 Error
It appears the website you are trying to visit is having technical difficulties or is no longer available.
Please go back and try your request again or try searching Google to find another website with what you're looking for!
Location: OZ, otherwise known as Oklahoma were the wind comes sweeping down the plains.
11/25/2013 11:07 AM
.com not ,com
11/25/2013 1:12 PM
11/25/2013 10:53 PM
Let me try to clarify a bit. There are several manuals (and videos) available at this website, but the particular one that I meant can be a little difficult to locate.
So, to be more specific, try;
www.rainbird.com/documents/turf/IrrigationDesignManual.PDF
Good Answers: 117
11/22/2013 11:08 PM
you seem to know what you what, have you taken your needs to a pump retailer?
Good Answers: 102
11/23/2013 4:11 AM
11/23/2013 4:59 AM
Hello. You have a simple application. This is not a process application where flow is critical - you simply want steady flow and a minimum pressure of 35-40 PSI. Assuming the well has been tested and does not risk "running dry" a 3/4 HP submersible pump should work fine for the distance and head you have indicated. In order to maintain a suitable flow you'll need to include a bladder tank and pressure control switch. This is not a storage tank - it is a tank with a diaphram that separates the water side from the air charge side. You'll need to set the air pressure against the bladder in accordance with the desired delivery pressure and adjust cut in/cut out pressures on the pressure switch. I would steer away from jet pumps. Foot valves can be a nuisance and loss of prime is common. Keep the submersible pump a minimum of 3-4' off bottom - even place a filter sock around it. If you have a 6" casing - recommend using torque arrestors. Don't forget to install a spring loaded check valve at the pump discharge. Submersible pumps are less maintenance.
11/23/2013 9:27 PM
Rainbird sprays have different nozzles that throw water out in different ways. Spray, large drops, low level, high and far etc. They do have a chart that tells you how far and how much water you get for a given pressure at the sprinkler. So...... step one, select the spray pattern you desire and then, step two, look for a pump that has the characteristics that you will need. The pump has a chart with it that shows its' pressure/flow characteristics. Step three, guess how many more sprinklers your wife will want you to add in the future, step four, measure your grade more accurately as you may end up with your sprinklers constantly running ( syphoning ) Step five, allow a bit extra for manufacturers fudge factor.
Jim
Register to Reply 21 comments
bigg (2); brich (1); Fredski (1); Grand Poobah (1); JIMRAT (1); lyn (5); MR. Guest (2); PWSlack (1); redfred (2); Steve Batey (1); tcmtech (2); Tornado (1); Wal (1)
