Previous in Forum: Resistance Value   Next in Forum: Project in Instrumentation
How to Change Profibus PA Device Healthy to Unhealthy?
11/30/2013 6:08 AM
Can anyone suggest me as how to change the profibus PA device say Siemens SITRANS TH400 healthy to unhealthy and vice versa.
Good Answers: 151
Re: How to Change Profibus PA Device Healthy to Unhealthy?
11/30/2013 2:14 PM
.Infect it with a virus?
11/30/2013 4:30 PM
  1. Reading the manual is one way.
  2. Contacting Siemens' Technical Helpline by telephone and talking it through with a specialist there is another.
  3. Hanging about and waiting for some knowledgeable person to be bothered to respond on CR4 is a very poor third.
11/30/2013 7:48 PM
A hammer would probably work in the first direction.
12/01/2013 8:18 PM
Good Answers: 122
12/02/2013 9:42 AM
"Healthy" status means there are no faults or issues in the system and the system is operating correctly.
"Unhealthy" status means there is a fault and/or issue in the system.
Faults and/or issues can be "minor" or "Major".
Minor means the system can operate but is limited and usually is automatically reset after the cause is repaired/removed.
Major means the system is stopped and inoperable until cause of the issue/fault has been removed/corrected and the system major fault table has been reset.
To make it "Healthy" you must correct, repair, and/or replace anything and everything that is not operating properly in the system. (I/O, Pwr. Supply, System backplane, card, communication system, etc.)
To make it unhealthy you just need to create an issue/fault but be careful as you could easily cause damage that is irreversible and for sure costly.
NEVER MAKE A SYSTEM UNHEALTHY WHEN IT IS ONLINE AND OPERATING AS YOU HAVE NO CONTROL OVER THE OUTCOME.
gringogreg (1); lyn (1); PWSlack (1); SHOCKHISCAN (1); Tornado (1)
