Previous in Forum: Battery Chargers in Parallel for a Lead Acid Battery Bank   Next in Forum: What is the Number Of This Fet?
10 comments
Factors Affecting Slip !!
12/04/2013 12:08 AM
Dear friends ,
What all are the factors/parameters ( design part) on which the slip of an induction motor depend ?
I mean what all parameters can be varied to change the slip ?
Re: Factors affecting slip !!
12/04/2013 12:17 AM
Search for "induction motor design" on the internet.
How to Search the Internet Effectively | MediaSmarts
We don't do homework. You have to do that yourself.
We don't do your work for you either.
If you are interviewing for a job, you're wasting your time.
12/04/2013 12:39 AM
Load.
Good Answers: 42
12/04/2013 2:48 AM
Load, of course. However for a same load if the rotor it is a wound-rotor induction motor you can control the speed [then the slip] by varying the exterior connected resistance.
If it is a squirrel cage rotor-it depends on how the bar and the slot are built [as dip bar, double cage and so on] the goal is to change the resistance-which it depends on skin effect mainly.
Julius
12/04/2013 2:59 AM
'... factors/parameters ( design part) on which the slip of an induction motor depend...'
-Is the induction motor of the type female, or simply male operating in drag?
-Is the slip supported via hip or shoulder?
-How much has the induction motor been drinking?
-What level of seriousness does one expect in replies to a post titled 'Factors affecting slip !!' (specifically the single-spaced, double-exclamation) that asks a question that begins as 'What all are...'?
The non-design part is another story, entirely.
Re: Factors Affecting Slip !!
12/04/2013 9:30 AM
12/04/2013 10:19 AM
Dear Mr.Solar Eagle,
Good Humour. Laughed Loudly.
DHAYANANDHAN.S
12/04/2013 10:25 AM
Dear Mr. Sibin,
The equation for slip of Induction Motor is that the TORQUE is PROPORTIONAL To Slip/Resistance in the Rotor Circuit. i.e. T = K x (S/R) where T is Torque, K is constant, S is Slip, and R is Resistance in the Rotor, decided during Design Stage.
Note: This applies to only to SLIP-RING MOTOR and NOT Squirrel Cage Motor.
DHAYANANDHAN.S
Good Answers: 141
12/04/2013 6:35 PM
By design:
Architecture and precision of the rotor cage and stator. (air gap) Iron volume and thickness of the sheets.
Plenty of room here
Good Answers: 170
12/05/2013 9:57 AM
R2 & X2 Sibin! Aren't they?
Good Answers: 137
12/05/2013 5:09 PM
Load and supply voltage.
I would assume slip varies linearly with load from zero at no load to manufacturer's figure (expressed as full-load speed) at design load. But somebody might disagree the details.
For voltage, there was a similar discussion back in October 2009, below is copy of a post then.
I came up with a formula relating motor speed to voltage, assuming, among other things, that back-EMF = applied volts at synchronous speed, and varies directly with speed.
ωV2 = (V22 * ωs - V12 * (ωs - ωV1)) / V22
where V1 = voltage 1, V2= voltage 2, ωV1 = speed at voltage 1, ωV2= speed at voltage 2, ωs = synchronous speed.
Agrees pretty well with published motor data.
As the speed increases slightly with increasing voltage, load power also increases, so the current falls a bit less than calculated from voltage ratios. In principle, the load could be modified to maintain constant power, but in practice it varies as speed3 for a squared-torque load, directly with speed for constant torque load.
Register to Reply 10 comments
7anoter4 (1); Codemaster (1); dhayanandhan (2); dvmdsc (1); electricalexpert65 (1); lyn (1); SolarEagle (1); Tornado (1); truth is not a compromise (1)
