Previous in Forum: Role of a Mechanical Engineer in a Cement Industry   Next in Forum: Crane On Sizer to Avoid Manual Handling
9 comments
Retest of Failed WPS
12/11/2013 3:58 AM
We have done PQR by welding EH36 & A514 Gr Q together,During the PQR test the materials failed in hardness test, requied value was 350Hv10 max and observed value was 380,400,...Hence this WPS is rejected.Does section IX allows to make a new test piece and check only hardness or again we need to do all the mechanical test(UTS,Impact).
Welding code:AWS D1.1
Re: Restest of Failed WPS
12/11/2013 4:14 AM
All of them. (Any change that corrects the hardness issue could affect the others.)
Good Answers: 104
Re: Retest of Failed WPS
12/11/2013 11:11 AM
You're assuming OP intends to change something! Re-read the title. (Scary, huh?)
12/11/2013 7:52 AM
I think you have done Temperbead PQR. Hardness is very important in temperbead welding.
12/11/2013 7:58 AM
Do not forget to do Bend tests (Face Bend,Root Bend and Side Bend according to thickness of test specimen) at the time of Tensile Test & Charpy 'V' notch Impact Test.
12/12/2013 12:29 AM
Following test has been done:Tensile,Side bend,Charpy & hardness
Anonymous Poster #2
12/11/2013 8:41 AM
A 514 Gr. Q .ie, Quenched&Tempered.
What about EH 36 condition?
Anonymous Poster #3
12/11/2013 9:20 PM
Hardness reading observed on WCL or FL or FL+2 or FL+5 ? If it was not in WCL then specify in which material location (A 514 Gr.Q or EH 36).
12/12/2013 12:27 AM
Hardness failed observed on WCL on A514 Gr Q
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
12/13/2013 6:16 AM
The problem is not to repeat the test. The most important thing is to determine WHY have you get that high hardness. If you do not optimize the welding parameters,and change WPS accordingly, you can pass the qualification and get bad production welds...
Kind regards
Register to Reply 9 comments
Anonymous Poster (4); bigg (1); Kwetz (1); Tornado (1); umesh vikram (2)
