Previous in Forum: Ventilation Fan Inrush Current   Next in Forum: Fault Current Calculation
40 comments
Help Requested - 3 Phase Rotary Switch Wiring
12/12/2013 12:00 AM
Hello CR4 Electrical Engineering Forum,
I have the task of replacing a rotary switch for a small 3 phase lathe. The original switch and markings are gone. The machine's motor is two speed, and the controls were set up for forward and reverse as well as off position. The machine is 220v, 60hz and the motor is a European AEG motor. The replacement rotary switch is a Square D switch.
The best way I can phrase my question, is what would be a good first step? The wiring diagram I have does not describe the internal wiring of the motor, and the rotary switch is out of production.
Motor leads are 1U 1V 1W and 2U 2V 2W.
Any help is appreciated! Thank you. Dan
Re: Help requested- 3 phase rotary switch wiring
12/12/2013 2:04 AM
The best first step is to call the motor manufacturer and discuss the problem directly with their technical helpline. Have the serial number of the motor available during the call.
Good Answers: 109
12/12/2013 2:34 AM
Not sure what you need the wiring of the motor for.
If you take the old switch apart and look at its internal wiring then you just connect the wires at the new the same way it was.
Make sure you know the wiring of the new switch.
Good Answers: 266
12/12/2013 7:46 AM
Square D makes quite a few rotary switches. Nice of you to give use a chance to guess which one.
If it is a drum switch like the one here on my Bridgeport mill. Then all it does is swap phasing between two leads. Three phase input is terminated on one side of the switches input terminals. Jumpers are ran to the other side of input terminals. Two of the jumpers are swapped.
Speed is changed with another switch.
Used these on some hanger doors back 30 years or so.
12/12/2013 5:17 PM
I tried to attach photos but can't seem to figure it out. The switch in question is a K4Y
P1055D.... good up to 7.5 hp at 220v. The motor is an AEG delta y motor....1.1/1.4kw
Motor leads at the terminal board on the motor are 1U 1V 1W on one side....and
2U 2V 2W on the other.
12/12/2013 7:28 PM
I rewired a saw in the workshop which had similar windings a few months ago. Will try to dig out wiring diagram tomorrow, if no-one's already posted it.
12/12/2013 7:33 PM
Does a reversing saw uncut your wood, so that you can try again?
12/12/2013 7:46 PM
Minute I hit "Submit ... " I knew some smart-a$$ was going to come up with something like that . 'Course the fekkin' saw didn't reverse, but it did change speed. Other side of switch would just be same pattern with 2 phases swapped.
Then again, with some of the incompetent gits in our workshop, maybe reversing it would be a good idea - could stick their fingers back on. Maybe I should re-rewire it to reverse.
12/13/2013 4:26 AM
I guess/hope you meant that as funny, though I am not sure myself. It was not clear....
I nearly always add a smiley to show my "direction" when I am being sarcastic.... Get it?
Changing direction of a 3 phase motor is the simplest thing to do, the method has already been posted in this blog, but for those who missed it, you only need to swap any 2 of the three phases with each other. It does not matter which. Obviously following electrical safety procedures.....
Many pumps with 3 phase motors turn in the wrong direction every day all day in some bad installations, often with obvious problems that nobody seems to understand, nor fix, sadly.....its important....but often completely missed at install time....
Some pumps will pump far less, some will run hot, it depends mainly on the pump design. Some won't work at all which is really good and informative....
Furthermore, a 3 phase saw may actually turn in the wrong direction when first connected and knowing the above means that the rotational direction can be easily, simply and correctly changed..!!
Just so's you knows and understands.....
PS. I am being funny/sarcastic Tornado, in case you did not get it.....
Have a great day!!
12/13/2013 11:04 AM
That would make a good Christmas gift
Canada - Member - New Member
12/13/2013 8:21 AM
Sounds like you may have a multi voltage motor. If you can't get the info from the manufacturer, any good motor repair shop should be able to check it out an tell you.
Never stop learning
12/13/2013 11:32 AM
Hers is a link to your switch:
http://www.ebay.com/itm/Rotary-Switch-Square-D-Type-K4Y-P1055D-5-position-/110334665012
Connections are as I described above.Any questions, feel free to ask.
Re: Help Requested - 3 Phase Rotary Switch Wiring
12/12/2013 10:32 AM
Does the switch change speed as well as direction?
12/12/2013 4:49 PM
Yes, the drum switch is the cylindrical panel mount type and has 5 positions, clockwise from 8 o'clock position, Low speed 2, Low speed 1, Off, High speed 1, High speed 2.
Good Answers: 104
12/12/2013 6:38 PM
That doesn't sound right - wouldn't it be forward hi, forward lo, off, reverse lo, reverse hi? Or vice versa. You wouldn't want to go from forward to reverse without going through off. Here's a link to an ABB 2-speed motor. You should be able to use a volt-ohm meter to see if yours is like this. With a meter and investigating the innards of the old switch as others have suggested, you should be able to figure it out.
12/12/2013 1:29 PM
Why is a 2-speed motor needed on a lathe? These things have gears and belts and all sorts of clever stuff to change the speed - just ask Del.
What suggests that the motor to hand is 2-speed? How did the call with the motor manufacturer go?
12/12/2013 4:54 PM
I was on this problem a year ago, at that time I called AEG Europe, they handed me off to AEG Canada, who then told me that my problem was indeed my problem.
The lathe by design is a two speed. Rated HP is available in high speed only, with the low speeds being used for delicate operations such as fine threading where torque is not so much of an issue. This machine combines gearing with motor speeds to offer a broader range of gearings.
12/12/2013 5:41 PM
Is it an original motor or a replacement?
What did the lathe manufacturer say about the motor and its wiring during the call to its Technical Helpline?
12/12/2013 5:58 PM
A year to sort this? Sheesh.
12/12/2013 5:45 PM
How many contacts do you need to change direction? Does your rotary switch meet those requirements.To determine the wiring of the motor and using a rotary switch to change direction should be a simple task for an electrician but if you are going to have two speeds as well it is going to be a bit more complex.Does your rotary switch have 5 positions?
12/12/2013 8:00 PM
Yep, 5 positions....it is a colossal task trying to wrap my head around all that needs to happen. The switch has 30 terminals and a bunch of jumpers to use.
Good Answers: 151
12/12/2013 7:03 PM
What is the original motor HP? You say it is a "small lathe" I would guess that the motor is about 5 HP. If the machine itself is in good condition, you might consider replacing the motor with a modern inverter duty 3 phase motor and using a variable speed drive. The cost would be about $1000 ( check out Automation Direct), but having the variable speed drive would make it a great machine tool.
12/12/2013 8:02 PM
The motor is a 1.1/1.4 kw.... I guess a half horse or third horse
12/12/2013 8:09 PM
More like 1.5 - 2 hp
12/12/2013 8:24 PM
This suggestion, in my opinion, has some serious merit and I will consider it especially. Although there is a ton of helpful information here, this suggestion makes separate motor speeds and analog controls a thing of the past. Then the reversing of the VSD might be more easily accomplished. Although the Emco Maximat 11 is a beautiful lathe, with excellent craftsmanship, the electrics can be seen as outdated and this suggestion opened my eyes to the prospect of using this breakdown as an opportunity to upgrade.
I'm limited in knowledge, I have no surviving original switch....as I mentioned. I have worked with three phase...and reversing, but wiring for speeds at the same time makes a very intricate drum switch necessary. Furthermore, the diagram does not show switch positions for different speeds, only the powered off layout of the components.
Good Answers: 151
12/12/2013 9:52 PM
I just checked Automation Direct catalog (www.automationdirect.com) and they list a 2 HP 3 phase 230 VAC inverter duty motor for $441 and a 230 Vac 3 phase 2 HP drive for $250..
I have no commercial interest in Automation Direct, but I have used them regularly for industrial automation equipment and have had great success with their products
12/13/2013 1:15 PM
I will call them. The switch to VFD could make the machine really flexible.
12/12/2013 7:07 PM
I would make sure the switch is break-before-make in all possible sequences.
Good Answers: 181
12/12/2013 10:35 PM
It's too late at night now. I have wired two speed machine tools before where they use Dahlander two speed motors. Will sort it tomorrow afternoon.
Good Answers: 104
12/12/2013 11:07 PM
Over at Practical Machinist, there has been similar discussion. One post leads to this(see fig. 7) which might be of some use. Does your motor nameplate have a connection diagram? That would help.
12/13/2013 1:10 PM
The motor has no such connection diagram, for reasons I cannot fathom, especially given the complexity of the problems if you don't have one.....
Good Answers: 104
12/12/2013 11:14 PM
Over my head, but you may have/need Dahlander Connection, explained here.
12/13/2013 12:18 PM
Yes, Yes, Yes.......Thank you...my data plate indicates delta star star.....also the
1U 1V 1W 2U 2V 2W match......my continuity checks also agree. The diagram is useful to me. Thank You.
12/12/2013 11:40 PM
Probably there is another switch which takes care of the speed selection, and for the forward reverse selection, any rotary switch that can interchange any two poles can do the job.First you have to assertain weather the original selector switch, was just a forward/ reverse switch or did it had a speed selector as well.
12/13/2013 12:23 PM
Believe it or not, there is an off on switch prior to the drum switch....and the drum switch functions to both reverse and change speeds.
12/13/2013 6:00 AM
Normally, on a lathe, the reversing of rotation is done mechanically via a lever and not by switching.
Maybe your rotary switch is used only for speed change.
12/13/2013 12:26 PM
I have a 14 X 40 Enco lathe which changes the rotation via a lever on the apron.....the attached shaft drives a small cam operating a micro switch only. It too is a two speed motor, by the way....and may also be Dahlander type.
Good Answers: 181
12/13/2013 8:57 AM
If it is a dahlander motor this may help.
I've shown contactors used for switching. I didn't write this for small machines.
http://www.electriciansboards.co.uk/topic/1063-dahlander-motors/
12/13/2013 11:27 AM
1U,1V and 1W are the low speed windings. 2U,2V and 2W are the high speed windings.
To change speeds, you must change all 3 phases simultaneously,and from a motor stopped condition,which means you must remove all power from the alternate speed first.
To reverse the direction,and to be effective on either speed, the power going INTO THE REVERSING SWITCH must be reversed,that is, 2 phases swapped.
So, to change speed, you need a 3 pole, double throw switch,which will have 9 terminals.
Connect the power to the center terminals, and the speed(s) to the top and bottom terminals.
The switch must have a center "Off" position,or be designed to break-before-make design.
I am not sure how your switch was constructed,unless it had a two-position shaft, for push-pull for speed or direction with stacked switches.
Can you send a picture of the switch or wiring?
12/13/2013 12:36 PM
The site tells how to post jpeg's but I have no idea how to perform what it is trying to say. I have photos at the ready.
The lathe has an off on switch on the front, then a 5 position speed and direction control knob, with the colossal drum switch behind it. I would know to kill the power before reversing or changing speeds. I don't know if the machine was designed fail safe in this manner.
Now the drum switch I bought is for separate windings for the speed change. It appears that Dahlander is more complex due to having to break 3 phases at the same time to perform the speed change. So the drum switch may need more terminals in order to perform the Dahlander type circuit. The K4Y I have has 30 terminals. Awesome input, Thank you.
12/15/2013 12:06 PM
Dahlander circuit- Reversing two speed
Register to Reply 40 comments
Andy Germany (1); bigg (3); eltech (1); gringogreg (2); HiTekRedNek (2); IdeaSmith (1); JohnDG (4); Kevin LaPaire (1); LAA_Lucke (1); Munster (1); ozzb (1); pillay (1); PWSlack (4); SEABEE (13); TonyS (2); Tornado (2)
