Previous in Forum: Heat Exchanger Flow   Next in Forum: Nitric Acid Tanker Design
Revision Question
12/30/2013 3:30 AM
In TIG, why we need to have a purging gas when performing root welding stainless steel.
thanks much :)
Re: revision question
12/30/2013 3:34 AM
To keep oxygen from being incorporated into the weld.
12/30/2013 3:45 AM
dear tornado,
may be you can explain more detail about my question. and make me more understand.
thanks much. :)
12/30/2013 3:56 AM
The molten weld metal can absorb small amounts of whatever gases are present. Oxygen, which is present I normal air, is undesirable. Purging with an inert (or other harmless) gas keeps the oxygen (or other problem gases) away from the weld.
12/30/2013 3:50 AM
In TIG inert gas is required.
Other wise, it would not be TIG.
Purging gas in inert.
Don't try to understand, just use it.
Not using it will not save you money. It will result in defective welds.
Look up purging gas on the internet.
Good Answers: 70
Re: Revision Question
12/31/2013 3:14 AM
Just curious, how much welding have you done in the past? Even a novice welder understands the importance shielding gases. It would do you no good if your inert gas line was filled/ contaminated with any other type of gas other than the shielding gases your going to weld with. And it doesn't matter what type of weld your doing, root or otherwise, contaminated gas = contaminated weld which sums up to a poor job,
SO, PURGE YOUR GAS LINE BEFORE STRIKING YOUR ARC
dj95401 (1); lyn (1); nik khairul amilin (1); Tornado (2)
