Previous in Forum: Nitric Acid Tanker Design   Next in Forum: Closed Circuit Air Line
Diesel Consumption
12/30/2013 10:59 PM
We have a 380 KVA Gense. How can i calculate the Units per litres.
Re: Diesel consumption
12/30/2013 11:06 PM
Dip stick, a little geometry, some method to measure output energy and some basic algebra usually works for me.
12/30/2013 11:14 PM
Fuel consumption kW (kVA) kW (kVA) kW (kVA)
Ratings 1800 (2250) 1600 (2000) 1320 (1650)
Load 1/4 1/2 3/4 Full 1/4 1/2 3/4 Full Full
US gph 31.7 58.1 85.9 115.3 30.1 52.7 76.9 103.9 84.4
L/hr 120 220 325 437 114 200 291 394 320
This didn't copy very well.
Did you ask the seller of the unit?
12/30/2013 11:22 PM
Dear Mr.Propel,
Pl.Open the following CR4 Link, and you will find PLENTY and PLENTY of details. I have also replied.
http://cr4.globalspec.com/comment/834912
dhayanandhan
Good Answers: 18
Find in discussion
Re: Calculate Fuel Consumption Per Day for Diesel Generator?
03/16/2012 10:57 PM
Dear Mr. Duffem,
It is calculated on the BASIS of SPECIFIC FUEL CONSUMPTION and 0.28 Lb./BHP per Hour, is the STANDARD at near FULL LOAD. At Partial Load - the Diesel Consumption will be high.
This topic raised few times and you will find quite a lot response from CR4 MEMBERS, from the Link given below:
http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=Diesel%20Consumption&order=asc&Pg=1
I have also responded earlier and the Link is:
http://cr4.globalspec.com/comment/699643
dhayanandhan Power-User
Join Date: May 2008 Location: CHENNI, TAMIL NADU, INDIA. Posts: 316 Good Answers: 1
22
Find in discussion
Re: Calculating Consumption for a Diesel Generator
02/27/2011 4:33 PM
Dear Guest,
The Diesel Consumption depends upon the Efficiency of the Engine and Generator. An efficient and GOOD set/system will have a Diesel Consumption of 206.28 gms/kW.Hr. as SPECIFIC FUEL CONSUMPTION at FULL LOAD.
At 75% FULL LOAD the same good DG SET will have a SPECIFIC FUEL CONSUMPTION of 205.9 gms/kW.Hr.
At No-Load the Diesel Consumption will be 10 to 10.2% of the Full Load consumption. Adultered Diesel will not fit in to this band, which will be less in CALORIFIC VALUE.
We should always try to run the set at Full Load or near Full Load in order to achieve best Fuel Economy.
A similar question appeared in this Forum about 6 months back and you can search in this Forum and many CR4 Members responded with their comments. In that Forum you will find that the Specific Fuel Consumption in FPS unit as 0.28 Lb/H.P.Hr (since I studied in FPS SYSTEM) posted by me.
Thanks,
DHAYANANDHAN.S
12/30/2013 11:40 PM
Dear Mr Dhayanandhan,
I am new to these type of activity. Is any simple formuls available to calculate Litres / Unit?
Thanks for your reply,
12/31/2013 1:07 AM
We are all qualified Engineers and specialized in a Particular Field. We should know the basics thoroughly. Hence the details given.
To answer your Question How Much Diesel/KW.Hr the single line Answer is:
Diesel Consumption of ONE LITRE, should give 3.3 to 3.4/KWHr. is the Good Performance - at 85% to 88% of full load.
DHAYANANDHAN.S
12/31/2013 12:16 AM
It depends on what Units [sic] you want to use. If litres, it will simply be 1 litre per litre; but this is not likely what you mean.
12/31/2013 12:21 AM
Ask the people who sold it to you!
Repeat: Ask the people who sold it to you!
Register to Reply 7 comments
Anonymous Poster (1); dhayanandhan (2); lyn (2); Propel (1); redfred (1)
