Previous in Forum: Building a New House and Very Nervous, Also Using a New Builder in Town   Next in Forum: Facade Contractor
15 comments
Ground Mount Solar Array
01/04/2014 12:11 AM
Can anyone tell me the calculations to use to calculate wind loads for a grount mount solar array that has 13 panel across and 3 row down. Each panel 40" and 65" long. It is 2 feet off ground in back and 5 feet in front. Wind speed into area is 85mph. On a hill at 28 degrees within a residential tract. Weight of panels is 45. I am using rebar reinforced concrete footings 36" deep and 18" wide. Spaced 12 feet across total of 4. And space 5.5 feet down total of three. Total footings 12. Please help. My building dept wants calc before they approve my permit. Thanks.
Re: Ground mount solar array
01/04/2014 12:41 AM
You can't do this. You should not even try.
"Wind speed into area is 85mph".
Large airplanes fly in winds slower than this.
You cannot stand in an 85 mile an hour wind. Debris will destroy these fantasy panels in 5 minutes.
Quit doing drugs!
Dorothy and Toto are waiting for you.
01/04/2014 1:16 AM
You might be in over your head....I would contact the company you bought the panels from and see if they provide this service, or can recommend somebody....In any case I don't think anyone will do it for free.....
http://solarprofessional.com/articles/design-installation/wind-load-analysis-for-commercial-roof-mounted-arrays
Good Answers: 70
01/04/2014 1:34 AM
Cut your loss and scratch the solar idea and plant wind turbines, you might have better production with those wind speeds
01/04/2014 2:15 AM
Trim the blades first.
01/04/2014 7:54 AM
can you install a webcam looking at the panels? on a windy day I want to watch them fly
Re: Ground Mount Solar Array
01/04/2014 12:33 PM
Your building department caught somebody unqualified to perform this design. You need to hire somebody licensed to do the correct analysis or give up on this project.
01/04/2014 1:57 PM
Try Googling "wind load calculations".
01/04/2014 5:13 PM
If they knew to Google for the correct calculation then they might be considered qualified but not certified. They would probably then be able to parse the relevant from irrelevant flood of answers that Google rapidly provides. So who are you helping?
01/04/2014 5:31 PM
Someone needs to explain how a solar panel will survive an 85 MPH impact from debris.
Not to mention surface abrasion from all the dust.
<unsubscribe>
01/04/2014 5:55 PM
The exact same way that a solar panel can survive reaching the escape velocity of the Earth, micro-meteorites at astronomical speeds and functioning perfectly well with no possible repairs for years after assembly. A qualified engineer analyzes the situations, crunches the numbers, and provides a design for others to scrutinize. Oh, I almost forgot, the engineer will also provide a bill for services rendered.
Good Answers: 125
01/04/2014 3:24 PM
Your project is feasable, however you need to hire a structural engineer to perform wind load calculations and specify footings and support structure.
Where I live, all solar installations are designed to withstand 150 MPH wind loads.
The reason your building officials want you to prove your system will withstand expected winds is because they are charged with protecting the public from your flying debris.
Good Answers: 29
01/04/2014 9:28 PM
By 'building dept' I'm assuming you mean building inspector. Most building inspectors want calculations done by and signed by a professional engineer. Your efforts at calculating wind load yourself may be moot. You should find out for sure before going too far and if need be find (and pay) a qualified and certified engineer to sign off on it.
When I installed my solar array, I bought my ground mount system through a dealer that designed the mount for me. Their engineer signed off on it and my county building inspector accepted that.
I'll second WJMFIRE's comment, in my area both roofs and solar installations are designed to withstand 90 mph winds. Lyn, it's the worst case scenario design criteria, not something he's likely to see often.
Good Answers: 117
01/05/2014 11:20 AM
Hire an engineer. Nothing less will satisfy the building inspector.
Good Answers: 179
01/05/2014 6:39 PM
There have been several threads exactly on this subject the past few years.
Did you perform a "Search" to see what you're getting into?
Calculating wind loads and performing structural calculations is not for the Layman, and are fairly complicated, plus you need to use engineering judgement because there are quite a few variables that have to determined based on the same sound judgement....educated guesses just won't do.
As other ahead of me have stated, hire a Licensed Professional Engineer, preferably a qualified Structural Engineer. Nothing less will satisfy the Code Enforcement Officer/Building Inspector.
01/06/2014 9:18 AM
IF you have 85 mph winds consistently, aren't you overlooking something amazing and possibly more useful than the solar input?
Consider installing a densely arranged array of wind generators upstream of the solar (far enough to not cast a shadow if the breezes are southerly (or northerly if you live in the Outback)). Then install a wind break to lift the breeze up and over the solar array, (of course this will have been built to withstand the same 85 mph winds.). Now you have precluded most of debris impacts, and hopefully limited sandblasting. With the solar system in the lee of the wind break, all should be well.
Hire a certified engineer to consider all the possibilities. Don't overlook all the potential, then build a solid system.
Register to Reply 15 comments
CaptMoosie (1); dj95401 (1); Fredski (1); James Stewart (1); Lo_Volt (1); lyn (3); redfred (3); SolarEagle (1); Tornado (1); WJMFIRE (1); Yusef1 (1)
