Previous in Forum: Radiography   Next in Forum: Material Handling
Compressors & Blowers
01/06/2014 10:39 AM
What is Difference between Compressor and Blower ? How they Work and Give thier Applications ?
Pathfinder Tags: blower Compressor
Re: Compressors & Blowers
01/06/2014 11:00 AM
a blower moves something like air, a compressor compresses gas. they can work in several ways, you can Google yourself to find more
01/06/2014 11:19 AM
Simple answer? The shape of their pressure/flowrate characteristic curves.
01/06/2014 12:38 PM
First, read this: How to Search the Internet - Hannon Library
Then you will be free from asking others to educate you and can find information independently of others.↓
Pumps, Compressors, Blowers and Fans - Engineering ToolBox
01/07/2014 4:20 AM
Why are you capitalizing all the nouns and verbs, and misspelling "their"?
In rough terms, a fan increases pressure and decreases volume by a small percentage.
A blower does the same by a larger percentage, a pump a still larger percentage, and a compressor yet larger again.
The dividing lines are inexact and overlapping, and depend on local terminology.
01/07/2014 6:39 PM
Hello Cr4 people
- compressors are used for gases only and it rises the pressure, depending upon the system.
compressors uses are : In refrigeration, Oxy. and Nit. gas planet that required a high pressure compressors, air compressor for tires filling and.....etc
- Blowers are used for air - as Mr. Tornado said - increases pressure and decreases volume by a small percentage.
Blowers uses are: In Ventilation for huge Store Houses which blow the air to inside the place to renew the air inside the store, also in some types of furnaces that needs blowers to supply air, portable blowers used in superficial cleaning in some places that need to blow the dust off .
But ... Pumps doesn't ever work gases
Best regards
Have a seat, relax, choose your words carefully, explain as detailed as possible .. I know it will take a couple minutes ... But you will get to the solution fast ..!
Fredski (1); lyn (1); PWSlack (1); Sulaiman Amr (1); Tornado (1)
