Previous in Forum: Foundation Fieldbus Signal Distance   Next in Forum: UL Certification
Double Acting Actuator!!
01/14/2014 12:06 PM
Hi Experts,
This is a general question regarding the use of volume bottle.
Is it possible to attain Fail Close position in Double acting pistion actuator with out the use of volume bottle.
Note: This is a modulating application and not ON-OFF.
Re: Double Acting Actuator!!
01/14/2014 1:47 PM
Then why do you need this bottle?
01/14/2014 1:51 PM
Yes. Change the double-acting one for a single-acting actuator.
Good Answers: 151
01/14/2014 2:08 PM
You could use a spring return on the rod end of a double acting cylinder. You would have to increase the overall stroke length of the cylinder to accommodate the spring, and this will effect the dynamics of the cylinder.
01/15/2014 12:49 AM
GA. Yes, the spring (force) on one side of piston would close when ever the system pressure fails. Should this to happen, there has be an arrangement to dump/relieve the oil (pressure) on either side of the piston when system pressure fails.
10/31/2024 8:26 AM
...which turns it into a single-acting actuator.
gringogreg (1); PWSlack (2); redfred (1); yesyen (1)
