Previous in Forum: UL Certification   Next in Forum: Hydraulic Tubing Bender and Fittings
IECEX
01/16/2014 3:39 AM
Dear All,
What is the role of IECEX.
For example, when the junction box certified with IECEX, is can be used to all region.
Is too many certification nowadays. Appreciate for advice
We Stare Because We Care
Re: IECEX
01/16/2014 5:31 PM
Please describe the application.
<subscribes>
Re: IECEX
01/19/2014 10:51 PM
Hi Pwslack,
The application for oil and gas industry;
I got project with AUSTRALIA LNG company that need the IECEX certified instrumentation such a JB, PT & TT.
Kindly advise what is the different with others certifications
Re: IECEX
01/20/2014 1:40 PM
The equipment has been constructed, tested and certified that, under prescribed conditions and appropriate levels of exposure to potentially explosive atmoshpheres, it does not contribute to explosions. The standards vary across the globe; there is a pan-European standard, for example, and a pan-North-American standard.
Asking the question suggests a lack of training, and the selection, installation and maintenance of hazardous area electrical equipment is not something for the untrained. So, stop work on the project, defer the project work to someone who has received the training, and only resume work on it once the training has been completed; local supervision will be able to arrange this on the basis that there are others at the facility that will have had suitable training.
Do find a way of typing the word Australia without using Caps Lock along the way.
<unsubscribes>
Re: IECEX
01/23/2014 4:03 AM
THANK YOU
Re: IECEX
01/20/2014 1:48 PM
Other hazardous area standards (such as ATEX, another common European hazardous area equipment standard) are not accepted in Australia.
If IECEx certified equipment is specified (and no allowance is provided to offer alternatively-certified equipment) you need to supply IECEx certified equipment (which is common).
You cannot (for example) supply industrial UL-only certified equipment as UL (and many other certification standards) are NOT suitable for hazardous areas.
More information can be found in the applicable IECEx standards and equipment certificates.
Banana86 (2); jack of all trades (1); PWSlack (2)
