Previous in Forum: Hydrogen Fuel   Next in Forum: No One at the Wheel
28 comments
Good Answers: 141
Changing Stud Bolt on Rear Wheel of 2003 Dodge Caravan
01/26/2014 8:26 PM
I bought a replacement stud for the rear wheel of our 2003 dodge grand caravan, because the tire man broke one.
I am planning to replace it on the spot if possible. The car sits 20 miles away and someone uses it there.
The rear wheels have drum brakes of which the covers slide over the rotor. The stud has been factory pressed-on (in) assembled.
I noticed that there is some space available, but have no idea if it is enough to have the bolt passed between the brake unit and the back side of the rotor.
I want to press it out with a tool that I made before to remove ball joints.
The other scenario is to take everything apart. A lot more job and time and tools required.
Anyone can tell me out of experience?
Thanks. D.
Plenty of room here
Re: changing stud bolt on rear wheel of 2003 dodge caravan
01/26/2014 9:34 PM
I have only used a torch to heat the metal around the bolt, and then punch out the stud....I would cut the stud close to the bone for clearance....
They do make special tools....
http://www.justanswer.com/chrysler/6quix-replace-rear-wheels-studs-2006-chrysler-town.html
Good Answers: 141
01/26/2014 10:26 PM
Thank you Solar Eagle. I only looked for dodge. but Chrysler is analog.
It is about the same tool I made for the ball joints. Good to know. I was afraid to have to take the rotor apart.
Plenty of room here
Good Answers: 141
06/19/2014 9:23 PM
Promised to come back on it.
It is the picture that solar eagle provides, but the bolt cannot be put in there without taking a lot apart. A hole could have been a easy solution, but none available.
Just to update. D
Plenty of room here
Good Answers: 444
Re: Changing Stud Bolt on Rear Wheel of 2003 Dodge Caravan
01/26/2014 10:50 PM
Have to agree with SE, cut it flush and punch it out with a hand sledge hammer and a punch, I was surprised at how easily it popped out.
Then you'll be faced with the real problem, how to find enough clearance to get the new, longer stud aligned with the hole. With some careful probing you will find that there is a hole or a depression in the backing plate that will just let the proper length stud go perpendicular to the mounting disk. Use a proper sized nut to pull the stud snug before you put on the wheel or may find that you pop it out from the back and you'll have to reinsert it.
01/27/2014 4:04 AM
"The tire man broke it"
Errrrr... shouldn't the tire man fix it then? He should have the facilities for such work. Mind, maybe you don't trust him, if he broke the damn thing in the first place.
Similar thing happened to my Daughter at a local tyre place, we found they had crossed the thread on one of her wheel studs (kids with air line nut runners - more power than finesse). We took it back and left it with them overnight, they fixed it, I had to saw the stud to length afterwards.
Good Answers: 141
01/27/2014 1:22 PM
Here everything is extra. Money.
When you have a contractor to pour a concrete slab. They pour more, ruin a lot an wait 1 week to remove the spills for extra $$. When i let them change the stud, it will be loose or the rotor will be cracked or damaged too.
I know how to do it. Just wanted to know if it works without removing the rotor, bearings etc..
Thank You
D.
Plenty of room here
01/27/2014 3:02 PM
I thought that was why you guys had guns
Good Answers: 141
01/28/2014 10:27 AM
Possession of fire arm here = 3 years in jail. Each round that fits it = 1 year extra.
These are the court rules here.
You can get a license, after application strict rules (gun safe etc...) and inquiry @$100.00 a year. Only for rifles.
Plenty of room here
01/28/2014 2:25 PM
...and where is that? "In the pool" is not much help!!
Good Answers: 141
01/28/2014 7:08 PM
Commonwealth of the Bahamas.
Plenty of room here
01/29/2014 3:50 AM
Nice!!!
01/28/2014 6:19 AM
GA
I would a)never use him again and b)I would warn all my friends against using him and his "boys".....
Good Answers: 141
01/28/2014 10:29 AM
There are maybe 8 here and they use the same skills and technology.
Plenty of room here
Good Answers: 137
01/27/2014 11:27 AM
What does the replacement stud look like? You should be able to tell how it's fitted, hence how to remove the broken one, and whether there's room to remove it.
One I did recently, the stud had tapered splines on the "back" end. It wasn't broken, I had a spare hub and wanted to keep a couple of studs just in case. I ran a wheel nut on the bolt, flat side out to about flush with end of the bolt, and tapped it out with a hammer, being careful to hit it nice and true. There was room to get it out OK.
Of course you need to have enough thread left on the broken stud to do that, but if not and it fits like mine you can just hammer it out, you're not worried about damaging the stud. It's possible there's room to get the broken one out, but not to get a full-length one in, though I doubt it. Let us know how you get on.
Good Answers: 141
01/27/2014 8:08 PM
Hi Del,
Looks like a bolt with a thicker end and a small collar. I'd like to press it out, because I don't want to hit the rotor with a hammer while the bearings are still in there.
Made a tool to press it out. The old one will pass, because it's broken and shorter.
Do not know about the new one. Seems like I will give it a try as soon as I feel to go there.
Plenty of room here
01/27/2014 10:51 PM
Knock out the remaining part with a good punch and ball peen hammer while wearing eye protection. Install the new one from the inside and pull it through with a wheel nut and a good spacer such as a nut one size bigger than the stud. Lube the threads with a good grease to prevent thread damage. Re install the wheel and torque the nuts to specs. Simple job and done it many times maybe not on a minivan though.
01/27/2014 10:58 PM
I have much experience with Chrysler rear hubs. First off, DO NOT HAMMER THE STUD OUT! If you do, you WILL have an ABS sensor failure. Maybe not right away, but within a couple of months it will start to trigger trouble codes. Hammering a stud out of a axle flange is the old way before integrated hub/sensors. Use a stud press to push it out. Insert the new stud(this will be tricky but possible)line up the splines and use a lug nut backwards, with a stack of washers and it will slide/pull right into place. Old school mechanics may disagree with me, and will be more than happy to replace the failed wheel hub, of course for $80 an hour for labor plus the $100 + their 20% markup for a new hub. All when they could've used a $12 tool to do it without damage.
01/27/2014 11:04 PM
Thanks I forgot about the sensors. Also damn expensive sometimes.
Good Answers: 137
01/28/2014 7:33 AM
That's a fair point. The one I did was a scrap hub so it didn't matter. You can remove the ABS sensor, I think the part inside the hub is just a notched metal disc and quite robust, but that still leaves the bearings. I'd be surprised if tapping the stud out caused a problem, you don't have to beat the living s**t out of it, but just in case......
Good Answers: 123
01/28/2014 9:04 AM
Go back and read #10. All I can add, is to put some grease on the washers to make them slide more easily. Good luck.
Bob
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
01/28/2014 10:03 AM
One thing you may think about doing is freezing the stud. An old mechanic's trick I was taught many years ago.
Speak softly and carry a big stick.
01/28/2014 10:13 AM
I must agree that cold on that rotor is easier on it than heat, although the press will most likely take care of the matter without either, cold would make this easier on the rotor, since the stud press would not be screwed down as tightly. Good answer! Yeah, don't let the weasel tire guy fix it, he probably knows nothing about bearings, and ABS sensors.
Good Answers: 141
01/28/2014 10:33 AM
The bolts are also pretty soft. The fitted part of it has some grooves to make room for material move.
Plenty of room here
01/28/2014 5:46 PM
I have a grand caravan sport and if I recall it should come out easily. a heavy hammer blow or two should knock it out of the hole, there should be enough wiggle room in there to get the stud out and maneuver the other in. usually they come out fairly easily, heat will make it easier but usually is not necessary. I replaced many of the studs on mine and don't think I had to do much for the back. It looks like there is not much room, but if you turn the hub you should be able to get the stud out. cutting off the stud is an option but is really unnecessary as there should be enough room behind it. I have replaced many of these and never had too much problem. once you get the new one on, just tighten the nut down to draw the new stud in place. drive it for a while and then tighten again to make sure it is fully seated.
Shawn P. Galloway
01/29/2014 3:49 AM
What about possible wheel bearing damage due to "hitting" it?
"a heavy hammer blow or two should knock it out of the hole"
I personally would try and use some form of "press" maybe with a judicial application of heat and cold in the right places (nowhere near the bearings/Grease seals with the heat!)......someone mentioned that correct tools are often available....I would use them if possible.
No heavy knocks as wheel bearings are an area where I don't want any failures, especially when driving!!
Even if no accident is caused, early life failure is now programmed in and the costs of some car wheel bearing replacement due to poorly thought out design, can be large.....though in my experience, not so bad on newer models...(at least on cars I have owned since 2000).
Years ago I had a Nissan that when replacing the front disks, you had to press the whole assembly off the axle, including the bearings, which meant that you replaced them anyway, doubling the costs.
The tool needed for that was a huge press - had to have it done by the Nissan dealership - never again Nissan!!!
01/28/2014 7:22 PM
The grooves in the stud are not to allow it to move, they are to prevent it from turning when you turn the lug nuts, and to keep them in place so they don't fall out.
Shawn P. Galloway
01/29/2014 6:37 AM
Fair point about the sensor. I would put a pry bar or block behind the hub then hit it this has never resulted in sensor problems but a press is cheap as well
Shawn P. Galloway
Good Answers: 137
01/29/2014 7:40 AM
But why not remove the sensor - #13? Then there's no risk of damage. Fixed by an M4 bolt on my Ford. But I agree to put a block behind the hub flange to reduce impact on the bearing.
Register to Reply 28 comments
Andy Germany (4); bob c (1); Codemaster (3); Drew85205 (1); dvmdsc (8); James Stewart (1); RAMConsult (1); roy hammy (2); SolarEagle (1); standarded (1); toolman911965 (3); user-deleted-1105 (2)
