Previous in Forum: Measuring The Level Of An Agitating Tank   Next in Forum: Catalog and Information About IFX/C04/P
Gang Operated Valve
01/28/2014 4:39 AM
Hi 2 All
how gang operated valve assembly works
can we have some kind of interlock in pneumatic scheme?
Good Answers: 18
Re: Gang Operated Valve
01/28/2014 7:23 AM
Not enough information. What do you mean by "gang operated valve assembly".
Information on the equipment and the application would help.
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
01/28/2014 7:25 AM
The Crips/Bloods/Jets/Sharks make up the operating staff.
01/28/2014 8:50 AM
In unison.
Yes.
Good Answers: 203
01/28/2014 11:01 PM
If they are ball valve they can, but not practical to do other than when all else won't work, is to modify the valves so that the ball can be operated from both the top and the bottom. Place appropriate rods from the top of each to the bottom of the valve above it with the balls in the same position all valves are then changed in unison by the handle on the top valve.
Another way for ball valve: place each valve next to another. Mechanically link the handles together in the same operating position. Move the mechanical link to adjust the valves in unison.
Most practical way: put identical pneumatic operators on each valve. With pipe fittings, operate each operator supply off the same air feed. Since the operator feeds are the same supply they will operate in unison with little variation. Suitable pneumatic control circuitry, what used to be called a pneumatic computer, can be installed should any variances in operation between valves not be acceptable.
Old style, old trick
Good Luck, Old Salt
02/01/2014 9:09 PM
It's all in the linkage
Toto, I've a feeling we're not in Kansas anymore
jesw55 (1); lyn (1); MagicWand (1); old salt (1); Tornado (1)
