Previous in Forum: MCCB Tripping While Star to Delta Changeover   Next in Forum: Pressure Sensitive Low Voltage Switch
8 comments
Contactor Working
02/03/2014 8:32 AM
Hi
Can you explain the working of a "reversing contactor" and normal "contactor"
Re: Contactor working
02/03/2014 9:02 AM
Re: Contactor Working
02/03/2014 2:50 PM
Yes. Why?
Good Answers: 804
02/03/2014 9:43 PM
I was not aware that reversing contactors were abnormal...
India - Member - New Member
Good Answers: 164
02/04/2014 8:59 AM
love giving unnecessary information Do you know 'normally closed' contactors ? Sometimes used for dynamic braking for example. They work in reverse logic. Not to be confused with what you wanted though.... just something new for you to learn. Sorry if this is confusing.
02/05/2014 9:28 AM
They have been around since "for ever" and their purpose is just that or to reverse a Load (normally a motor .. but I have used them in other applications -before PLCs back in the Relay Logic days).
On a 3 phase motor they reverse the motor direction by "swapping: to leads (L1 & L3). ALL "Good" reversing contacts have a LOCK Out device that prevents the same load from being told to go the opposite direction at the same time (BAD)..
~Ole Sarge~ I am older (at least than I was Yesterday) and I am retired Military
Good Answers: 42
02/05/2014 9:32 AM
Normal contactor are used for reversing with change of connection. But reverse contactors and only used for reversing purpose ony.
Good Answers: 42
02/05/2014 9:44 AM
A reversing contactor
ome / Sensors, Automation, Safety Systems / Motor Control / Contactors / Magnetic Motor Contactors / Reversing Contactor 135A 3P 120/110V 60/50Hz Open
EATON - W211K4CF
EATON
Manufacturer # W211K4CF
CBC #78211421434
Good Answers: 42
02/05/2014 10:03 AM
A nice demonstration of reversing switich is given in U tube. Just visit it.
http://www.youtube.com/watch?v=nKDG3Ja4d8A
Register to Reply 8 comments
JRaef (1); kvsridhar (1); PWSlack (1); Tom_Consulting (1); topturner (1); V.I.Abraham (3)
