Previous in Forum: Contactor Working   Next in Forum: HV Feeders
Pressure Sensitive Low Voltage Switch
02/03/2014 9:21 AM
I am looking for a pressure sensitive switch. Smallest I can find. Let's say {Switching}Volts 200VDC 0.5 Amps {Carry} 10vA 1.5 = when pressure is put on the switch it closes & when pressure is released it opens. not a plunger. Something flat.
Anyone have any ideas?
Re: Pressure Sensitive Low Votage Switch
02/03/2014 11:07 AM
What applies the pressure?
Gas, water, finger, air?
Operating environment?
Operating range? On at?/Off at?
Please give clues, we don't like 20 questions.
02/03/2014 2:34 PM
A window or door.
02/03/2014 2:17 PM
A low votage switch? To remove hanging chads?
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
Re: Pressure Sensitive Low Voltage Switch
02/03/2014 11:15 PM
Your heading says "...low voltage... " 200VDC is NOT low voltage!
The 200VDC at 0.5A kills any miniature switch. DC switching at that voltage requires the contacts to separate a significant distance to break the arc at turn-off. You need to use a low voltage at the flat switch to energize a relay or other larger switching device to control the 200V.
For the (low voltage, low current) flat switch, look at those used in remote controls, key fobs, etc.
02/03/2014 11:52 PM
I think you are looking for force or displacement sensitive, rather than pressure. Some MicroswitchesTM may be able to handle 200VDC, 0.5A.
Good Answers: 73
02/04/2014 12:33 PM
Not to be a pessimist, but it is helpful to know if you are expecting a pressure increase or decrease on the occasion of the event. And for that matter, consider that once a pressure difference has been detected, is it likely to remain stable in that condition or will enough air bleed off so that is no longer a differerence?
These questions will help characterize the condition you wish to measure or detect so that you can build the device you are thinking about.
Perhaps you could find/make/or borrow a manometer
to see what really happens.
08/23/2024 10:09 AM
Yes.
  • There is a tool called Google.
  • There is a tool called RS Components.
  • There is a tool called Farnell.
  • There is a tool called Amazon.
  • etc.
Try some of those, perhaps?
Register to Reply 7 comments
dkwarner (1); lyn (1); Mike W (1); NotUrOrdinaryJoe (1); PWSlack (1); Santa800 (1); Tornado (1)
