Previous in Forum: CT's Secondary Terminal Earthing   Next in Forum: Synchronizing Problem
Conservator Shutter Valve
02/05/2014 11:28 AM
Hi all, How could We test Conservator Shutter Valve on 100 MVA transformer? (Sergi, TL 34)
Either exist as you are or be as you look. Rumi
Good Answers: 73
Re: Conservator Shutter Valve
02/05/2014 11:54 AM
Why would you ask us when the manufacturer can do a much better job at answering that?
02/05/2014 12:30 PM
I wonder, Is anybody here has experience about Conservator Shutter Valve testing ?
02/05/2014 12:59 PM
Yep. The equipment manufacturer does. That's why the testing will be in the User Manual supplied with it. If this document is nowhere to be found, a simple telephone call will invoke a replacement.
02/05/2014 1:14 PM
Probably not. What would have lead you to believe that Conservator Shutter Valve testing experts reside here?
02/05/2014 12:15 PM
Turn on, measure current flow.
Turn off, measure current flow.
Good Answers: 445
02/05/2014 9:15 PM
The Conservator Shutter Valve (CSV) is part of the Sergi Transformer Protector system. It is a passive device that is triggered when there is an unusually high flow of oil from the conservator tank.
You could try opening the main tank drain valve, slowly increase the flow rate, and note the flow rate at which the CSV initially operates. Make sure you have a reservoir to collect the oil so that you can refill the tank before you re-energize the transformer.
If you think this is a dumb idea, then follow all the previous posters' suggestions and contact Sergi directly, they're probably going to wonder why you don't believe them when they say "...trust us, we know our system works as advertised..."
02/06/2014 1:59 AM
Try www.sergi-france.com, they made it they should know.
Register to Reply 7 comments
beentheredonethat (1); engilis (1); lyn (2); NotUrOrdinaryJoe (1); PWSlack (1); RAMConsult (1)
