Previous in Forum: Series Capacitor 3p Motor Starting   Next in Forum: Earth Leakage Monitoring
Load Angle
02/06/2014 9:54 PM
Is it true that when load angle of a synchronous generator increases, load increases. How it occurs.
Thanks
Re: Load Angle
02/06/2014 10:30 PM
Only Allah knows for sure.
The next time you speak with Him, ask.
Re: Load Angle
02/07/2014 1:27 PM
common knowledge...less common than common sense
Re: Load Angle
02/07/2014 1:41 AM
Load angle is very much about things like power factor and current flow.
It's all a bit beyond me. True of most things, so I find going with the flow helps.
Is it the weekend yet ?
Re: Load Angle
02/07/2014 3:07 AM
Maybe a useful analogy would be slip in an induction motor. Also, I think the order of events is that as the load increases, the load angle responds by also increasing.
Re: Load Angle
02/07/2014 6:56 AM
The correct sentence is "when the active load increases the load angle increases", to reach a balance between the torque on the shaft and the resistant electrical torque on the generator terminals.
The load angle or power angle, δ, is the angle between the induced EMF and the voltage at generator terminals.
It represents, in each moment, the angular position of the polar wheel between the no-load and load positions. For a stable system, a variation Δδ of the load angle must match a variation ΔP of the same sign.
The static stability limit is defined as the maximum power that the machine can exchange with the network without losing the synchronism in response to a slow load variation and without excitation current variation.
For a cylindrical rotor machine, the static stability limit is reached when δ = ± π/2, thus the stable working area corresponds to -π/2 < δ < + π/2.
For more detailed information, please refer to synchronous machines theory.
Best regards, SMCTR
Re: Load Angle
02/07/2014 1:07 PM
Register to Reply 6 comments
Anonymous Poster (1); Kris (1); lyn (1); SMCTR (1); The.Tinkerer (1); Tornado (1)
