Previous in Forum: Safety Valve ASME UV-1 Form   Next in Forum: Metal Weighy Calculator
02/19/2014 5:59 AM
If the purchase order of the safety valve stated that the valve shall be ASME approved and stamped UV, and the valve manufacturer refuses to submit the UV-1 form
(FORM UV-1 MANUFACTURER'S OR ASSEMBLER'S CERTIFICATE OF CONFORMANCE FOR PRESSURE RELIEF VALVES)
(CERTIFICATE OF SHOP COMPLIANCE)
As Required by the Provisions of the ASME Boiler and Pressure Vessel Code Rules, Section VIII, Division 1))
And reply (the valve nameplate stamped by UV and this is enough, the UV-1 form is internal form and does not received to the purchaser)
In this case, does the purchaser have the right to rejects this valve?
Ask right person to get the right answer.
This discussion was "closed" on 02/19/2014 8:56 AM. No new comments are allowed.
Message from admins:
Duplicate Thread http://cr4.globalspec.com/thread/88387/safety-valve-ASME-UV-1-Form
Re: safety valve ASME UV-1 Form.
02/19/2014 6:08 AM
Duplicat thread. Reported to Admin.
02/19/2014 6:39 AM
sorry, but the new is
the valve manufacturer reply (the valve nameplate stamped by UV and this is enough, the UV-1 form is internal form and does not received to the purchaser)
02/19/2014 6:41 AM
Please discuss in the original thread only. Duplicate threads run contrary to the CR4 Rules of Conduct.
02/19/2014 6:46 AM
ok, thanks.
Register to Reply 4 comments
