Previous in Forum: DIY HDMI Cables and Connectors   Next in Forum: CEAG Central Battery System
Control Valve
02/19/2014 8:19 AM
Dear All
I've power up the control vlv without connecting air supply, any such proble arise without air supply, coz would like to check the parameter of the control vlv IP using hart 475.
Rgds
Moh'd
Re: control vlv
02/19/2014 8:31 AM
w/o air no wk cn b dn
wht knd ip has hart
Toto, I've a feeling we're not in Kansas anymore
Re: Control Valve
02/19/2014 1:19 PM
technology has gone a long way in utilizing the talents of our youth, but not every case.
Re: Control Valve
02/20/2014 9:01 AM
Haha!
Re: Control Valve
02/19/2014 2:30 PM
No problem. Go ahead.
Re: Control Valve
02/20/2014 9:02 AM
It's time to put some air on that keyboard too. Some of the keys appear not to work.
Good Answers: 73
Re: Control Valve
02/24/2014 12:13 PM
Excellent! r u sur its th k ys?
Good Answers: 203
Re: Control Valve
02/26/2014 11:07 PM
A P #1-
Can't supply any humor tonight, all laughed out, BUT ---->
It depends upon the type of valve you are using. Solenoid valves generally need a slight pressure on them to operate, no air no operate. Pilot operated valves require air to the pilot to operate the valve, no air no operate. If the valve is operated with an air cylinder independent of the air passing through the valve and the cylinder has a spring return on it, the valve will operate. Note that the air to the cylinder can not be the air that is passing through the valve, it must be an independent supply of air.
Otherwise the system will not operate.
Good Luck, Old Salt
Fredski (1); lyn (1); MagicWand (1); NotUrOrdinaryJoe (1); old salt (1); PWSlack (2)
